Help Center/ Huawei Cloud Flexus_Huawei Cloud Flexus X Instance/ User Guide/ Cloud Eye Monitoring/ Configuring Alarm Rules for a FlexusX Instance
Updated on 2025-07-29 GMT+08:00
Configuring alarm rules for FlexusX instances allows you to customize the monitored objects and notification policies. Then, you can monitor your FlexusX instances more carefully.
This section describes how to configure an alarm rule for a FlexusX instance.
Configuring an Alarm Rule on the Cloud Eye Console
- Log in to the Cloud Eye console and click
in the upper left corner to select a region. - In the navigation pane, choose Alarm Management > Alarm Rules.
- On the Alarm Rules page, click Create Alarm Rule to create one, or modify an existing alarm rule. For details, see the following:
After an alarm rule is configured, the system automatically notifies you when an alarm complying with the alarm rule is generated.
