Updated on 2025-01-26 GMT+08:00
Unsubscribing from a FlexusRDS for PostgreSQL Instance
To delete a DB instance billed on the yearly/monthly basis, you need to unsubscribe the order. For unsubscription fees, see Unsubscription Rules.
  • A DB instance cannot be unsubscribed when any operations are being performed on it. It can be unsubscribed only after the operations are complete.
  • If a backup of a DB instance is being restored, the instance cannot be unsubscribed.
  1. In the instance list, select the target instance and click Unsubscribe above the instance list.
  2. In the displayed dialog box, enter YES.
  3. Click OK.
    After you unsubscribe from an instance order, the instance will be deleted and it is no longer displayed in the instance list.
