Buying a FlexusRDS for PostgreSQL Instance
This section describes how to purchase a FlexusRDS for PostgreSQL instance on the FlexusRDS console.
FlexusRDS for PostgreSQL only supports the yearly/monthly billing mode. It allows you to tailor your compute resources and storage space to your business needs.
- You have created a Huawei ID and enabled Huawei Cloud services.
- Your account balance is greater than or equal to $0 USD.
- Go to the FlexusRDS console.
- If this is your first time to create a DB instance on this console, click Buy.
- Configure the instance information and click Buy.
Figure 1 Selecting an instance class
Figure 2 Selecting the required duration
Table 1 Basic information Parameter
Region
Region where your resources are located.
NOTE:Products in different regions cannot communicate with each other through a private network. After a DB instance is created, the region cannot be changed. Therefore, exercise caution when selecting a region.
DB Engine
Select PostgreSQL.
Instance Class
An instance class includes vCPUs, memory, storage, and DB instance type.
- Storage: The purchased storage space. After a DB instance is purchased, you can configure storage autoscaling. The maximum allowed storage is 4,000 GB. For details, see Enabling Storage Autoscaling for a FlexusRDS for PostgreSQL Instance.
- DB Instance Type
- Primary/Standby: An HA architecture. When a primary instance is being created, a standby instance is provisioned along with it to provide data redundancy. The standby instance is invisible to you after being created.
- Single: A single-node architecture. It is less expensive than a primary/standby DB pair.
Network
A Virtual Private Cloud (VPC) is a virtual network in which your instance is located. A VPC can isolate networks for different workloads.
A subnet provides dedicated network resources that are logically isolated from other networks for security purposes.
For details about how to create a VPC and subnet, see Creating a VPC and Subnet.
DB Instance Name
Must start with a letter and consist of 4 to 64 characters. Only letters (case-sensitive), digits, hyphens (-), underscores (_), and periods (.) are allowed.
If you buy multiple DB instances at a time, their names will include a four-digit suffix. For example, if you specify instance here, the names will be instance-0001, instance-0002, and so on. If existing instances' suffixes have already reached up to 0010, the new instance names will start from instance-0011.
Required Duration
The system will automatically calculate the configuration fee based on the selected required duration. The longer the required duration is, the larger discount you will enjoy.
Auto-renew
- This option is not selected by default.
- If you select this option, the auto-renew cycle is determined by the selected required duration.
Quantity
You can buy a maximum of 50 DB instances at a time. If you intend to create primary/standby DB instances and set Quantity to 1, a primary instance and a synchronous standby instance will be created.
- Confirm the order.
Figure 3 Order confirmation
- If you need to modify your settings, click Previous.
- If you do not need to modify your settings, click Pay Now.
- Select a payment method and complete the payment.
- To view and manage your instance, go to the instance list page.
- When your instance is being created, the status is Creating. The status changes to Available after the instance is created.
- Automated backup is enabled by default during instance creation and cannot be disabled. An automated full backup is immediately triggered once your DB instance is created.
- The default administrator account of your DB instance is root.
- During instance creation, the system randomly sets a password for the administrator account. You need to reset the password before you can connect to the instance. For details, see Resetting the Administrator Password of a FlexusRDS for PostgreSQL Instance.
- The default database port is 5432 and cannot be changed.
