Viewing Details of a FlexusL Instance
After purchasing a FlexusL instance, you can view and manage it on the FlexusL console. This section describes FlexusL instance details and related operations.
- Log in to the FlexusL console and click a resource card or instance name to go to the instance details page.
- View the FlexusL instance details.
Table 1 FlexusL instance details Item
Data Package
- Expiration time: A FlexusL instance provides a monthly data package. The traffic quota included in the data package is reset each month. Any unused portion of the data package cannot be rolled over to the next month.
For example, if you purchase a FlexusL instance for three months at 10:00:00 on June 5, the data package for the first month will be valid from 10:00:00 on June 5 to 00:00:00 on July 6. The data package for the second month will be valid from 00:00:00 on July 6 to 00:00:00 on August 6. The data package for the final month will be valid from 00:00:00 on August 6 to 00:00:00 on September 6.
- Available: The remaining traffic in the monthly data package.
- Used: The traffic volume that has been used in the current month.
- Traffic usage: The traffic usage in the current month, which can be calculated using the following formula: Traffic usage = Used traffic/Total traffic volume in a data package
Network
An EIP and a private IP address.
Server
The name, status, and operation entries of the cloud server.
OS installed on the cloud server.
Data Monitoring
Common monitoring information. For more information, see Monitoring FlexusL Instances Using Cloud Eye.
- In the navigation pane on the left, choose Cloud Servers to view server overview information.
Table 2 Cloud server overview Server Details
Name/ID
Cloud server name or ID
Status
Server status
Security
Servers scanned by HSS
: No risks detected.
: Risks detected. You can view risk details on the console.
Specifications
vCPUs, memory, system disk, and bandwidth of a server
IP address
Private IP or EIP of a server
Operation
Operations supported by a server
- View Monitoring Data: Go to the Cloud Eye console to view the monitoring metrics of the FlexusL instance. For more information, see Monitoring FlexusL Instances Using Cloud Eye.
- Remote Login: Select a login mode as required. For more information, see Login Modes.
- Reset Password: A FlexusL instance does not have an initial password. You will have to reset a password.
- Stop: Stop the FlexusL instance.
- Configure Security Group Rule: For details, see Configuring the Security Group for a FlexusL Instance.
- Restart: Restart the FlexusL instance.
- Reinstall OS: If the OS of the cloud server is abnormal, reinstall the OS. For details, see Reinstalling the OS of a FlexusL Instance.
- Change OS: Change the OS of the FlexusL instance. For details, see Changing an OS.
- Click the server name to go to the server details page.
You can view server details on the Overview, Domain Names, Security Groups, Disks, and Network Interfaces tabs.
Table 3 Cloud server details Tab
Overview
On the Overview tab, you can view the following information:
- Basic information: including the instance name, ID, region, and expiration time.
- Configuration information: including the vCPUs/memory, disk capacity and type, bandwidth, and image.
- Network information: including the network interface name and IP address (used for communication between instances), VPC, EIP (used for internet access), and security group.
Domain Names
On the Domain Names tab, you can:- View domain names.
- Add, resolve, disable, or delete a domain name. For details, see Adding and Resolving a Domain Name for a FlexusL Instance.
Security Groups
On the Security Groups tab, you can:- View inbound and outbound security group rules.
- Change the security group. For details, see Changing the Security Group of a FlexusL Instance.
- Configure security group rules. For details, see Configuring Security Group Rules for a FlexusL Instance.
Disks
On the Disks tab, you can view disk details, including the disk ID, mount point, capacity, and encryption status.
Network Interfaces
On the Network Interfaces tab, you can:- View network interface details, including the ID, EIP, private IP address, security group, and MAC address.
