Backing Up a FlexusL Instance
CBR enhances data integrity and service continuity. For example, if a FlexusL instance is faulty or a misoperation causes data loss, you can use backups to quickly restore data. This section describes how to back up a FlexusL instance.
Preparations
Before backing up a FlexusL instance, ensure that your FlexusL instance has been associated with CBR.
- If you have purchased CBR along with a FlexusL instance, the FlexusL instance is automatically associated with CBR.
- If you do not associate a vault with the FlexusL instance during the purchase, you can buy a vault afterwards on the CBR console and associate it with the FlexusL instance. For details, see Creating a Cloud Server Backup.
Method 1: Auto Backup Based on the Backup Policy
After you associate a cloud backup vault with a FlexusL instance server during the purchase, the cloud server can be automatically backed up based on the policy. You can view or modify the backup policy on the FlexusL console.
- Log in to the FlexusL console and click a resource card or instance name to go to the instance details page.
- On the displayed page, choose Cloud Backup Vaults from the navigation pane on the left and click Apply Policy in the upper right corner.
- View or set the backup policy parameters. For details about the parameters, see Backup policy parameters.
More frequent backups create more backups or retain backups for a longer time, protecting data to a greater extent but occupying more storage space. Set an appropriate backup frequency as needed.
- Click OK.
After creating the backup policy, ensure that the cloud servers are automatically backed up based on the policy.
Method 2: Manual Backup
- On the FlexusL console, obtain the server name or ID, or the backup vault name or ID so that you can quickly find the associated vault on the CBR console.
- If you associate a vault with a FlexusL instance server during the purchase, search by either server name or ID, or vault name or ID.
Log in to the FlexusL console, click a resource card, and choose Cloud Servers or Cloud Backup Vaults from the left navigation pane to obtain the server name or ID, or vault name or ID.
- If you associate a vault with a FlexusL instance server on the CBR console after the FlexusL instance is created, search by server ID.
- Log in to the CBR console and choose Cloud Server Backups. On the Vaults tab in the right pane, search for the vault using the obtained vault name or ID, and click Perform Backup in the Operation column.
- Set a backup name and determine whether to enable Full Backup.
Full Backup: If enabled, a full backup task will be performed for the cloud server. If not, an incremental backup task will be performed.
- Click OK to start the backup immediately.
You can view the created backup on the Backups tab page and use the backup to restore data when needed.
Follow-Up Operations
After backing up the cloud server data, you can use the backup to restore the server. For details, see Restoring from a Cloud Server Backup.
