Creating a Container Service
You can buy FlexusCCI and create containers on the console. You only need to specify container images and compute resource specifications required by container services to run various applications (from simple web applications to multi-layer microservices).
- Log in to the FlexusCCI console.
- In the upper right corner of the page, click Buy FlexusCCI.
- Configure the parameters.
- Basic Configuration
Table 1 Basic configuration for a container service Parameter
Billing Mode
Only pay-per-use is available.
Region
Select the region where FlexusCCI will be used. Cloud service products in different regions cannot communicate with each other over a private network. Select a nearest location for low latency and fast access.
- Container Setting
There are two ways to create containers: using a template or specifying the configuration.
Table 2 Parameters for creating a container using a template Parameter
Configuration Type
Select Template. There are three options: Nginx, Hello World, or WordPress.
Container Name
- The container name cannot be changed after creation. If you need to change the name, create another container.
- Enter 1 to 63 characters. Start and end with a letter or digit. Use only lowercase letters, digits, and hyphens (-).
Port
- Nginx port number: 80
- Hello World port number: 80
- WordPress port numbers: TCP 80 or TCP 3306
Public Network Setting
Container port: 80
Table 3 Parameters for creating a container by specifying the configuration Parameter
Configuration Type
Select Custom Configuration. Specify the container information as required.
Container Name
SWR Image Address
- My Images: images that you have uploaded to SWR. For details, see Uploading an Image Through a Client.
- Open Source Images: public images in the image center.
- Shared Images: images shared by others through SWR.
- If you are an IAM user, you need to request permissions by referring to Organization Management before using private images in the account.
- Currently, FlexusCCI does not support third-party image repositories.
- A single layer of the decompressed image must not exceed 20 GB.
Image Tag
Select an available image tag.
Startup Command
(Optional) Enter the container startup command, which will be executed upon container startup. Startup commands correspond to the ENTRYPOINT startup instructions of the container engine.
Container Port
- The port ranges from 1 to 65535. You can specify the listening port of the application as the container port.
- The protocol can be TCP or UDP. This parameter is optional.
Environment Variables
- Variable Name: Enter a name of the environment variable.
- Value: Enter a value. This parameter is optional. Environment variables provide great flexibility for applications. You can assign values to environment variables when creating containers. The values will be read when containers are running.
Specify the container port that will be mapped to the port on the EIP. In this way, the container can be accessed from the Internet.
- Flavor
Two flavors are available: 2 vCPUs and 4-GiB memory and 4 vCPUs and 16-GiB memory. Set this parameter based on the runtime of the application.
CAUTION:
After a container service is created, the flavor cannot be changed.
- Container Service Name
The name must be unique. Enter 1 to 63 characters starting and ending with a letter or digit. Only lowercase letters, digits, hyphens (-), and periods (.) are allowed. Do not enter consecutive periods or place a hyphen before or after a period.
A container service can contain multiple containers.
- Click Buy Now.
