Help Center/ Elastic Volume Service/ User Guide/ Using IAM to Grant Access to EVS/ Using IAM Identity Policies to Grant Access to EVS
Updated on 2026-05-26 GMT+08:00
System-defined permissions in identity policy-based authorization provided by Identity and Access Management (IAM) let you control access to EVS resources. With IAM, you can:
  • Create IAM users or user groups for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing EVS resources.
  • Grant users only the permissions required to perform a given task based on their job responsibilities.
  • Entrust a Huawei Cloud account or a cloud service to perform efficient O&M on your EVS resources.
If your Huawei Cloud account meets your permissions requirements, you can skip this section.
Figure 1 shows the process flow of identity policy-based authorization.
You have learned about the system-defined identity policies for EVS in Identity Policy-based Permissions Management. To grant access to services other than EVS, see System-defined Policies/Roles.
Process Flow
Figure 1 Process of granting EVS permissions
  1. On the IAM console, create an IAM user or create a user group.
  2. Attach a system-defined identity policy (EVSReadOnlyPolicy as an example) to the user or user group.
  3. Log in as the IAM user and verify permissions.
    In the authorized region, perform the following operations:
    • Choose Service List > Elastic Volume Service. Then click Buy Disk on the EVS console. If a message appears indicating that you have insufficient permissions to perform the operation, the EVSReadOnlyPolicy policy is in effect.
    • Choose another service from Service List. If a message appears indicating that you have insufficient permissions to access the service, the EVSReadOnlyPolicy policy is in effect.
Example Custom Policies
  • Example 1: Grant permissions to create disks.
        "Version": "5.0",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                                    "evs:volumes:create",
                                    "evs:volumes:list",
                                    "evs:volumes:get",
                                    "evs:types:get",
                                    "evs:quotas:get",
                                    "ecs:cloudServerFlavors:get",
                                    "ecs:cloudServers:listServersDetails"
  • Example 2: Create a custom policy containing multiple actions.
    A custom policy can contain the actions of one or multiple services. Example policy containing multiple actions:
        "Version": "5.0",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "evs:volumes:list"
                "Effect": "Allow",
                "Action": [
                    "evs:volumes:list",
                    "evs:volumes:get",
                    "evs:types:get",
                    "evs:quotas:get",
                    "evs:volumes:use"
                "Effect": "Allow",
                "Action": [
                    "ecs:cloudServers:listServersDetails",
                    "ecs:cloudServers:showServer",
                    "ecs:cloudServers:attach",
                    "ecs:cloudServers:detachVolume"
  • Example 3: Grant permissions to forcibly create encrypted disks.
    You can create a custom policy to force users to create only encrypted disks.
        "Version": "5.0",
        "Statement": [
                "Effect": "Deny",
                "Action": [
                "Condition": {
                    "Bool": {
                        "evs:Encrypted": [
                            "false"
  • Example 4: Grant permissions to forcibly create backups for disks.
    You can create a custom policy to force users to use cloud backup when creating disks.
    When forcible backup is configured and you are creating a yearly/monthly disk, you must choose an existing backup vault.
    Example policy:
        "Version": "5.0",
        "Statement": [
                "Effect": "Deny",
                "Action": [
                "Condition": {
                    "Null": {
                        "cbr:VaultId": [
                            "true"
