Changing the EVS Disk Type (OBT)
As your services grow, the performance of your existing disks may no longer meet your service requirements. For example, data processing may slow down or response times may increase. At this point, improving disk performance becomes essential to support ongoing service growth. You can address this issue by changing to a disk type that offers higher performance.
| Phase | Description |
| Before the change |
| During the change |
| After the change |
The following table lists the supported disk type changes.
Supported disk type changes vary by region. You can view the allowed changes on the console.
| Original Disk Type | New Disk Type |
| Extreme SSD V2 | Extreme SSD V2 (IOPS changed) |
| General Purpose SSD V2 | General Purpose SSD V2 (IOPS or throughput, or both changed), Ultra-high I/O, General Purpose SSD, Extreme SSD V2, or Extreme SSD |
| Extreme SSD | General Purpose SSD V2 (IOPS or throughput, or both changed), Ultra-high I/O, Extreme SSD V2, or General Purpose SSD |
| Ultra-high I/O | General Purpose SSD V2 (IOPS or throughput, or both changed), Extreme SSD, Extreme SSD V2, or General Purpose SSD |
| General Purpose SSD | General Purpose SSD V2 (IOPS or throughput, or both changed), Extreme SSD, Extreme SSD V2, or Ultra-high I/O |
| High I/O | General Purpose SSD V2 (IOPS or throughput, or both changed), Extreme SSD, Ultra-high I/O, or Extreme SSD V2, General Purpose SSD |
| Common I/O (previous generation product) | General Purpose SSD V2 (IOPS or throughput, or both changed), Extreme SSD, Ultra-high I/O, General Purpose SSD, or High I/O |
Impact on the System
During a disk specifications change, data read and write operations continue normally and services are not interrupted. However, the change may temporarily affect the disk performance. Therefore, you are advised to perform the change during off-peak hours to avoid any impact on service stability.
Billing
After a disk specifications change, the billing of the disk will also be changed:
- For a pay-per-use disk, the disk will be billed based on the billing standards for the new disk type.
- For a yearly/monthly disk, the disk expiration time remains unchanged, and the system will calculate the price difference based on the remaining days and the price difference between the original and new disk specifications.
You are advised to create a snapshot for the disk to back up the disk data before changing the disk specifications. For details, see Creating an EVS Snapshot.
- Sign in to the EVS console.
- In the disk list, locate the target disk, click More in the Operation column, and choose Modify Specifications.
The Modify Specifications page is displayed.
- Select a disk type from the drop-down list. The system shows the new price based on your selection.
To change to the General Purpose SSD V2 type, you also need to specify the disk IOPS or throughput or both.
To change to the Extreme SSD V2 type, you also need to specify the disk IOPS.
- Click Submit.
The disk list page is displayed. If the disk type changes to the target type, the change is successful.
If the disk is a yearly/monthly disk, the expenditures may change. Handle resource change orders in a timely manner.
Helpful Links
- To learn more about the disk performance, see Disk Types and Performance.
- After a disk type change, the performance of the disk is not only determined by the new disk type. It is also determined by the instance that the disk is attached to. For details, see Instance QoS.
- For details about how to test disk performance, see Testing EVS Disk Performance.
- You can view the disk performance through monitoring data. For details, see Viewing EVS Disk Monitoring Data.
