Basic EVS Monitoring Data
This section describes monitored metrics reported by EVS to Cloud Eye as well as their namespaces and dimensions. You can use the console or APIs provided by Cloud Eye to query the metrics of the monitored objects and alarms generated for EVS. For how to configure alarm rules, see Setting Alarm Rules.
Namespace
SYS.EVS
Metrics
If you find that your disk throughput or IOPS is high or exceeds the upper limit, you are advised to change the disk to a type with high specifications by referring to Changing the EVS Disk Type (OBT). To learn more about disk types and performance, see Disk Types and Performance.
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
Monitoring Period (Raw Data) |
disk_device_read_bytes_rate |
Disk Read Bandwidth |
Number of bytes read from the monitored disk per second |
≥ 0 |
bytes/s |
1024 (IEC) |
EVS disk |
5 minutes (instantaneous value of the collection point) |
disk_device_write_bytes_rate |
Disk Write Bandwidth |
Number of bytes written to the monitored disk per second |
≥ 0 |
bytes/s |
1024 (IEC) |
EVS disk |
disk_device_read_requests_rate |
Disk Read IOPS |
Number of read requests sent to the monitored disk per second |
≥ 0 |
requests/s |
N/A |
EVS disk |
disk_device_write_requests_rate |
Disk Write IOPS |
Number of write requests sent to the monitored disk per second |
≥ 0 |
requests/s |
N/A |
EVS disk |
disk_device_queue_length |
Average Queue Length |
Average number of read or write requests waiting for processing in the monitoring period for the monitored disk |
≥ 0 |
count |
N/A |
EVS disk |
disk_device_io_util |
Disk I/O Utilization |
Percentage of time the monitored disk was performing read or write operations in the monitoring period |
0-100 |
N/A |
EVS disk |
disk_device_write_bytes_per_operation |
Avg Disk Bytes Per Write |
Average number of bytes transmitted per I/O write for the monitored disk in the monitoring period |
≥ 0 |
KB/op |
N/A |
EVS disk |
disk_device_read_bytes_per_operation |
Avg Disk Bytes Per Read |
Average number of bytes transmitted per I/O read for the monitored disk in the monitoring period |
≥ 0 |
KB/op |
N/A |
EVS disk |
disk_device_write_await |
Disk Write Await |
Average await time per I/O write for the monitored disk in the monitoring period |
≥ 0 |
ms/op |
N/A |
EVS disk |
disk_device_read_await |
Disk Read Await |
Average await time per I/O read for the monitored disk in the monitoring period |
≥ 0 |
ms/op |
N/A |
EVS disk |
disk_device_io_svctm |
Disk I/O Service Time |
Average service time per I/O read or write for the monitored disk in the monitoring period |
≥ 0 |
ms/op |
N/A |
EVS disk |
disk_device_io_iops_qos_num |
IOPS Upper Limit Reached (Count) |
Number of times that the IOPS of the monitored disk has reached the upper limit |
≥ 0 |
count |
N/A |
EVS disk |
5 minutes (accumulated value) |
disk_device_io_iobw_qos_num |
Bandwidth Upper Limit Reached (Count) |
Number of times that the bandwidth of the monitored disk has reached the upper limit |
≥ 0 |
count |
N/A |
EVS disk |
Dimension
Key |
Value |
disk_name |
- You can obtain the server ID and drive letter by referring to Querying a Single Disk Attached to an ECS.
- You can obtain the disk ID by referring to Querying Details About an EVS Disk.
Viewing Monitoring Data
- Sign in to the EVS console.
- Choose Storage > Elastic Volume Service.
The Elastic Volume Service page is displayed.
- In the EVS disk list, click the name of the disk you want to view the monitoring data.
The disk details page is displayed.
- On the Servers tab, locate the row that contains the server and click View Metric in the Operation column.
The Monitoring Metrics page is displayed.
- View the disk monitoring data by metric or monitored duration.
