Supported Metrics
This section describes metrics reported by enterprise switches to Cloud Eye as well as their namespaces, metrics, and dimensions. You can use the Cloud Eye management console or APIs to obtain the metrics and alarms generated for enterprise switches.
Namespace
SYS.ESW
Monitoring Metrics
With Cloud Eye, you can monitor the network status of enterprise switches.
ID |
Name |
Description |
Value Range |
Unit |
Conversion Rule |
Monitored Object (Dimension) |
Monitoring Interval (Raw Data) |
up_bandwidth |
Outbound Bandwidth |
Network traffic per second going out of the enterprise switch |
≥ 0 |
bit/s |
1024 (IEC) |
instance_id |
1 minute |
down_bandwidth |
Inbound bandwidth |
Network traffic per second going into the enterprise switch |
≥ 0 |
bit/s |
1024 (IEC) |
instance_id |
1 minute |
up_stream |
Outbound Traffic |
Network traffic going out of the enterprise switch |
≥ 0 |
byte |
1024 (IEC) |
instance_id |
1 minute |
down_stream |
Inbound Traffic |
Network traffic going into the enterprise switch |
≥ 0 |
byte |
1024 (IEC) |
instance_id |
1 minute |
up_pps |
Outbound PPS |
Packets per second going out of the enterprise switch |
≥ 0 |
pps |
N/A |
instance_id |
1 minute |
down_pps |
Inbound PPS |
Packets per second going into the enterprise switch |
≥ 0 |
pps |
N/A |
instance_id |
1 minute |
Dimensions
The metric measurement dimension of an enterprise switch is instance_id.
Key |
Value |
instance_id |
Enterprise switch ID. You can obtain the enterprise switch ID on the cloud service monitoring page of the Cloud Eye console. |
