Creating a Flow Log
This section describes how to create a flow log to record information about the traffic of enterprise router attachments.
Only one flow log can be created for an attachment in the same log group and log stream.
- Go to the enterprise router list.
- Search for the target enterprise router by name.
- Click the enterprise router name and click Flow Logs.
The flow log list is displayed.
- On the Flow Logs tab, click Create Flow Log.
The Create Flow Log dialog box is displayed.
- Configure the parameters based on Table 1.
Table 1 Parameters for creating a flow log Parameter
Setting
Example Value
Name
Mandatory
Enter a name for the flow log. The name:- Must contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
flowlog-ab
Resource Type
Mandatory
Select the type of the resource whose traffic information is to be collected. The enterprise router flow log function can capture traffic of the following attachments:- VPC
- Virtual gateway: Virtual gateway of Direct Connect
- Peering connection: Enterprise routers in other regions. You can add enterprise routers from different regions to a central network as attachments. Each connection between enterprise routers is a peering connection attachment.
- VPN gateway
- Global DC gateway: Direct Connect global DC gateway
VPC
Resource
Mandatory
In the resource list, select the resource whose traffic information is to be collected.
vpc-ab
Log Group
Mandatory
Select a log group.
If there is no log group, click Create Log Group.
lts-group-ab
Log Stream
Mandatory
Select a log stream.
If there is no log stream, click Create Log Stream.
lts-topic-ab
Optional
Describe the flow log as required.
- Click OK.
- View the flow log status.
If the flow status changes from Creating to Enabled, the flow log is successfully created.
