Updated on 2025-03-06 GMT+08:00
Creating a VPC Attachment
This section describes how to attach a VPC to an enterprise router so that the VPCs attached to the enterprise router can communicate with each other.
  • If you use the propagated routes of a VPC attachment, the route table of the enterprise router automatically learns the VPC CIDR block as the destination of routes. The CIDR block cannot be changed. To ensure that routes in the route table do not conflict, the CIDR blocks of all VPCs attached to the enterprise router cannot overlap. Otherwise, communication fails.
  • If your existing VPCs have overlapping CIDR blocks, do not use propagated routes. Instead, manually add static routes to the route table of the enterprise router. The destination of the routes can be VPC subnet CIDR blocks or smaller ones.
  1. Go to the enterprise router list.
  2. Search for the target enterprise router by name.
  3. Go to the Attachments tab using either of the following methods:
    • In the upper right corner of the enterprise router, click Manage Attachment.
    • Click the enterprise router name and click Attachments.
  4. On the Attachments tab, click Create Attachment.
    The Create Attachment page is displayed.
  5. Configure the parameters based on Table 1.
    Table 1 Parameters for adding a VPC attachment
    Setting
    Example Value
    Name
    Mandatory
    Enter an attachment name. The name:
    • Must contain 1 to 64 characters.
    • Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    er-attach-01
    Attachment Type
    Mandatory
    Select VPC, indicating that a VPC is to be attached to the enterprise router.
    The methods for creating attachments vary depending on the attachment type. For details, see Attachment Overview.
    VPC
    Attached Resource
    Mandatory
    1. Select the VPC to be attached to the enterprise router. You can enter a VPC name to quickly find the target VPC.
    2. Select a subnet in the selected VPC. You can enter a subnet name to quickly find the target subnet.
      • You can select any subnet in the VPC. All subnets in the same VPC can communicate with each other by default and the enterprise router can connect to the entire VPC.
      • You are advised to select a subnet that is dedicated for connecting to the enterprise router. To ensure that the subnet has enough IP addresses for the system and the enterprise router, make the subnet mask /28 or smaller.
    • VPC: vpc-A
    • Subnet: subnet-A01
    Auto Add Routes
    Optional
    • Enable this option if you want to automatically add routes (with this enterprise router as the next hop and 10.0.0.0/8, 172.16.0.0/12, and 192.168.0.0/16 as the destinations) to all route tables of the selected VPC.
    • Do not enable this option if an existing route in the VPC route tables has a destination set to 10.0.0.0/8, 172.16.0.0/12, or 192.168.0.0/16 because the routes will fail to be added. After the attachment is created, manually add routes to the VPC route tables.
    This parameter is only displayed when a VPC attachment is created. It cannot be enabled after the VPC attachment is created.
    Enable
    Optional
    Describe the attachment for easy identification.
    Tag
    Optional
    Add tags to help you quickly find your attachment.
    For details, see Overview.
    If you have configured tag policies for attachments, you need to add tags to your attachments based on the tag policies. If you add a tag that does not comply with the tag policies, attachments may fail to be created. Contact the administrator to learn more about tag policies. For details about tag policies, see Tag Policy Overview.
    Tag key: test
    Tag value: 01
  6. Click Create Now.
    The attachment list is displayed.
  7. Check the attachment status.
    If the status changes from Creating to Normal, the attachment is successfully created.
Follow-up Procedure
If Default Route Table Association and Default Route Table Propagation are not enabled for an enterprise router, you need to:
  1. Create a custom route table for the enterprise router. For details, see Creating a Route Table.
  2. Create associations for the attachments of the enterprise router. For details, see Creating an Association for an Attachment in a Route Table.
  3. Use either of the following methods to add routes for the attachment to the route table:
