Help Center/ Enterprise Router/ User Guide/ Associations/ Creating an Association for an Attachment in a Route Table
Updated on 2026-07-14 GMT+08:00
You can refer to the following operations to create an association in the route table of an enterprise router to associate an attachment with the route table. After an association is created, packets from the attachment are forwarded based on the association route table, and the attachment network can automatically learn the routes in the association route table.
Each attachment can only be associated with one route table. Packets from the attachment will be forwarded based on the route table.
Automatically Creating an Association When Creating an Attachment
If the Default Route Table Association function is enabled for an enterprise router, adding an attachment to the enterprise router automatically creates an association in the specified association route table. The attachment will forward packets based on the association route table and automatically learn its routes.
As shown in Figure 1, ER-01 has the Default Route Table Association function enabled. Adding an attachment to the enterprise router will automatically create an association between the attachment and the association route table defaultRouteTable.
Figure 1 Default Route Table Association enabled
To enable the Default Route Table Association function, refer to the following:
  • When creating an enterprise router, you can enable the Default Route Table Association function. The system will automatically create a default route table as the association route table. For details, see Creating an Enterprise Router.
  • After an enterprise router is created, you can enable the Default Route Table Association function and change the association route table. For details, see Modifying Enterprise Router Settings.
Creating an Association for an Existing Attachment
  1. Go to the enterprise router list.
  2. Search for the target enterprise router by name.
  3. Go to the Route Tables tab using either of the following methods:
    • In the upper right corner of the enterprise router, click Manage Route Table.
    • Click the enterprise router name and click Route Tables.
  4. Click the route table where you want to create an association. On the Associations tab, click Create Association.
    The Create Association dialog box is displayed.
  5. Configure the parameters based on Table 1.
    Table 1 Parameters for creating an association
    Setting
    Example Value
    Attachment Type
    Mandatory
    Select an attachment type.
    • VPC: A VPC is attached to the enterprise router.
    • Virtual gateway: A Direct Connect virtual gateway is attached to the enterprise router.
    • VPN gateway: A VPN gateway is attached to the enterprise router.
    • Peering connection: The enterprise router connects to another enterprise router in a different region.
    • Global DC gateway: A Direct Connect global DC gateway is attached to the enterprise router.
    • CFW instance: A VPC border firewall is attached to the enterprise router.
    For more information, see Attachment Overview.
    VPC
    Mandatory
    In the drop-down list, select the attachment to be associated with the route table.
    er-attach-02
    Route Policies
    Optional
    When any of the following attachment types is selected, you can configure a route policy for the association of the attachment to control the routes from the enterprise router to the attachment:
    • Virtual gateway
    • VPN gateway
    • Global DC gateway
    In the Route Policy drop-down list, select a route policy.
    For more information about route policies, see Route Policy Overview and Associating a Route Policy with an Enterprise Router.
    routePolicy-ab
  6. Click OK.
    The association list is displayed. You can view your association.
