Updated on 2026-07-14 GMT+08:00
Association Overview
Each attachment can be associated with one route table for:
  • Packet forwarding: Packets from the attachment are forwarded through the routes specified in the associated route table.
  • Route learning: The routes in the associated route table are automatically learned for the attachment.
Figure 1 Associations
Table 1 Associations
Attachment Type
Route Learning
Way to Create Association
VPC
Not supported
  • Auto creation: If Default Route Table Association is enabled and the default association route table is specified, attachments are automatically associated with the default association route table.
  • Manual creation: You can select a route table and create an association in it to associate an attachment with the route table. For details, see Creating an Association for an Attachment in a Route Table.
Each attachment can only be associated with one route table. Associations between attachments in Figure 1 are described as follows:
  • Auto creation: Associations are automatically created to associate attachments, such as peering connection 2, global DC gateway 1, VPC 1, and VPN gateway 1, with the default route table of the enterprise router.
  • Manual creation: You need to manually create associations in the custom route table of the enterprise router for attachments, such as VPC 2, VPN gateway 2, peering connection 3, and global DC gateway 2.
Virtual gateway
Supported
VPN gateway
Supported
Peering connection
Supported
Global DC gateway
Supported
CFW instance
Not supported
