Updated on 2025-03-06 GMT+08:00
Modifying a Route Table
This section describes how to modify the name and description of a route table.
Only the name and description of route tables named defaultRouteTable and custom route tables can be changed.
  1. Go to the enterprise router list.
  2. Search for the target enterprise router by name.
  3. Go to the Route Tables tab using either of the following methods:
    • In the upper right corner of the enterprise router, click Manage Route Table.
    • Click the enterprise router name and click Route Tables.
  4. In the route table list, click next to the name of the target route table.
    The Modify Route Table dialog box is displayed.
  5. Enter a new name.
    Table 1 Parameter description
    Setting
    Example Value
    Name
    Mandatory
    Enter a new name for the route table. The name:
    • Must contain 1 to 64 characters.
    • Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    er-rtb-01
    Optional
    Modify the description of the route table.
  6. Click OK.
    The route table list is displayed.
