Help Center/
Enterprise Management/
User Guide/
Project Management/
Managing Enterprise Projects/
Converting a Test Project to a Commercial Project
Updated on 2025-11-04 GMT+08:00
You can change a test project to a commercial project based on service requirements. Currently, commercial projects cannot be converted to test projects.
- Log in to Huawei Cloud console.
- Choose Enterprise > Project Management in the upper right corner of the page.
If the screen resolution is low, choose More > Enterprise > Project Management.
Figure 1 Project Management
- Choose More > Modify in the Operation column of the row containing the test project to change.
Figure 2 Changing a test project into a commercial project
- Click OK.
Parent topic: Managing Enterprise Projects
