Key Operations Recorded by CTS
You can use CTS to record operations on ELB for query, auditing, and backtracking.
Table 1 lists the operations recorded by CTS.
| Action | Resource Type | Trace Name |
| Configuring access logs | logtank | createLogtank |
| Deleting access logs | logtank | deleteLogtank |
| Creating a certificate | certificate | createCertificate |
| Modifying a certificate | certificate | updateCertificate |
| Deleting a certificate | certificate | deleteCertificate |
| Creating a health check | healthmonitor | createHealthMonitor |
| Modifying a health check | healthmonitor | updateHealthMonitor |
| Deleting a health check | healthmonitor | deleteHealthMonitor |
| Adding a forwarding policy | l7policy | createL7policy |
| Modifying a forwarding policy | l7policy | updateL7policy |
| Deleting a forwarding policy | l7policy | deleteL7policy |
| Adding a forwarding rule | l7rule | createl7rule |
| Modifying a forwarding rule | l7rule | updateL7rule |
| Deleting a forwarding rule | l7rule | deleteL7rule |
| Adding a listener | listener | createListener |
| Modifying a listener | listener | updateListener |
| Deleting a listener | listener | deleteListener |
| Creating a load balancer | loadbalancer | createLoadbalancer |
| Modifying a load balancer | loadbalancer | updateLoadbalancer |
| Deleting a load balancer | loadbalancer | deleteLoadbalancer |
| Adding a backend server | member | createMember |
| Modifying a backend server | member | updateMember |
| Removing a backend server | member | batchUpdateMember |
| Creating a backend server group | pool | createPool |
| Modifying a backend server group | pool | updatePool |
| Deleting a backend server group | pool | deletePool |
