Updated on 2026-11-05 GMT+08:00
Adding an HTTP Listener
You can add an HTTP listener if content identification is required. HTTP is a great fit for workloads such as web applications and mobile mini-games.
  • HTTP listeners can only be associated with HTTP backend server groups.
  • If you only select the network load balancing type for your dedicated load balancer, you cannot add HTTP listeners to this load balancer.
  1. Go to the load balancer list page.
  2. On the displayed page, locate the load balancer and click its name.
  3. On the Listeners tab, click Add Listener. Configure the parameters based on Table 1.
    Table 1 Parameters for configuring an HTTP listener
    Frontend Protocol
    Specifies the protocol that will be used by the load balancer to receive requests from clients.
    Select HTTP.
    Listening Port
    Specifies the port that will be used by the load balancer to receive requests from clients.
    The port number ranges from 1 to 65535.
    Name (Optional)
    Specifies the listener name.
    Redirect to another listener
    Specifies the HTTPS listener to which HTTP requests are redirected to encrypt the communication and improve service security.
    For example, if you configure an HTTP redirection, HTTP access to a web page will be redirected to the HTTPS listener you select and handled by the backend servers associated with the HTTPS listener. As a result, the clients access the web page over HTTPS. Note that the configurations for the HTTP listener will not be applied. Requests will be forwarded to backend servers by the HTTPS listener.
    After the redirection is configured for an HTTP listener, the backend server will return 301 Moved Permanently to the clients.
    Transfer Client IP Address
    This option is enabled for dedicated load balancers by default.
    When you use an HTTP listener to forward requests, you can use the X-Forwarded-For header to transfer client IP addresses. The first IP address recorded in the X-Forwarded-For header is the client IP address.
    For details, see Using Dedicated Load Balancers to Transfer Client IP Addresses.
    Advanced Forwarding
    Specifies whether to enable advanced forwarding. This option allows you to configure advanced forwarding policies to forward requests to different backend server groups, facilitating flexible traffic distribution and proper resource allocation.
    For more information, see Advanced Forwarding.
    Access Control
    Specifies how access to the listener is controlled. For details, see What Is Access Control?
    All IP addresses is selected for access control by default.
    You can select Whitelist or Blacklist and choose an IP address group.
    • Whitelist: Only IP addresses in the whitelist can access the listener. Requests from the IP addresses or IP address ranges specified in the IP address group will be forwarded by the listener.
    • Blacklist: IP addresses in the blacklist are not allowed to access the listener. Requests from the IP addresses or IP address ranges specified in the IP address group will not be forwarded by the listener.
    More (Optional)
    Data Compression
    Specifies whether to enable the data compression option. If you do not enable this option, files will not be compressed.
    Brotli and Gzip can compress the files in the following format:
    text/html, text/xml, text/plain, text/css, application/javascript, application/x-javascript, application/rss+xml, application/atom+xml, application/xml, application/json
    This option is available in certain regions. You can see which regions support this option on the console.
    Retry on Other Backend Servers
    Specifies whether to allow the load balancer to attempt to establish connections with other backend servers in the same backend server group, if it fails to connect to a backend server.
    If all four retries fail, error code 502 or 504 will be returned.
    • Connection error: If the load balancer cannot connect to a backend server due to an error, such as a failed or rejected connection, error code 502 will be returned.
    • Request timeout: If the backend server does not respond within the timeout duration, error code 504 will be returned.
      • Connection timeout: The load balancer attempts to connect to a backend server but fails within the timeout duration.
      • Response timeout: The load balancer has sent a request to a backend server but does not receive a response within the timeout duration.
    Note: If an error occurs after the load balancer forwards a request using a non-idempotent request method, such as POST, PATCH, or DELETE, the load balancer will not retry the request.
    Idle Timeout (s)
    Specifies the maximum duration during which no data is transferred between the load balancer and a client. If no data is transmitted during this period, the load balancer closes the connection and establishes a new one when the next request is received.
    The idle timeout duration ranges from 0 to 4000.
    Request Timeout (s)
    Specifies how long the load balancer waits for a client request. It includes:
    • The timeout duration for the load balancer to read the request header from the client. If the client does not send a complete request header within this duration, the request is interrupted.
    • The maximum interval between two consecutive requests received by the load balancer.
    The request timeout duration ranges from 1 to 300.
    Response Timeout (s)
    Specifies how long the load balancer waits for a response from a backend server. If the backend server does not respond within the configured timeout, the load balancer retries the request on another backend server. If no backend server responds, the load balancer stops waiting and returns the HTTP 504 error code.
    If sticky session is enabled and the load balancer receives no response from the backend server within the response timeout duration, the load balancer does not retry the request and returns the HTTP 504 error code directly.
    The response timeout duration ranges from 1 to 300.
    Maximum New Connections per AZ
    Specifies the maximum number of new connections that a listener can handle per second in each AZ. Unlimited is selected by default. You can select Limit request to set the maximum number of new connections.
    The value ranges from 1 to 1000000. If the value is greater than the number defined in the load balancer specifications, the latter is used as the limit.
    Maximum Concurrent Connections per AZ
    Specifies the maximum number of concurrent connections that a listener can handle per second in each AZ. Unlimited is selected by default. You can select Limit request to set the maximum number of concurrent connections.
    Reducing the concurrent connection limit does not interrupt established connections.
    Tag
    Adds tags to the listener. Each tag is a key-value pair, and the tag key is unique.
    Description (Optional)
    Provides supplementary information about the listener.
    You can enter a maximum of 255 characters.
    HTTP Headers
    Select HTTP headers as needed.
    • Transferring client information
      • Rewrite X-Real-IP to transfer the client IP address.
      • Rewrite X-Forwarded-For-Port to transfer the client port.
      • Rewrite X-Forwarded-Host to transfer the client domain name.
    • Transferring load balancer information
      • Rewrite X-Forwarded-Proto to transfer the listener protocol.
      • Rewrite X-Forwarded-ELB-IP to transfer the load balancer EIP.
      • Rewrite X-Forwarded-Port to transfer the listener port.
      • Rewrite X-Forwarded-ELB-ID to transfer the load balancer ID.
    For details, see HTTP Headers.
    More HTTP headers are coming soon. See the available HTTP headers on the management console.
  4. Click Next: Configure Request Routing Policy.
    1. You are advised to select an existing backend server group.
    2. You can also select Create new to create a backend server group.
      1. Configure the backend server group based on Table 3.
      2. Click Next: Add Backend Server. Add backend servers and configure a health check for the backend server group.
        For details about how to add backend servers, see Backend Server Overview. For the parameters required for configuring a health check, see Table 4.
  5. Click Next: Confirm.
  6. Confirm the configurations and click Submit.
Popular Questions
