Configuring Modification Protection and Deletion Protection for Dedicated Load Balancers
You can enable modification protection and deletion protection for load balancers to prevent them from being modified or deleted by accident.
- Deletion Protection: prevents your load balancers from being deleted by accident. Disable Deletion Protection if you want to delete a load balancer.
- Modification Protection: prevents your load balancers from being modified by accident. Disable Modification Protection if you want to modify or delete a load balancer.
Enabling or Disabling Deletion Protection
- Go to the load balancer list page.
- On the displayed page, locate the load balancer and click its name.
- Switch to the Summary tab of the load balancer and enable or disable Deletion Protection.
If your load balancer is managed by CCE, modifying the load balancer will affect the running of the CCE cluster.
- After deletion protection is enabled, the load balancer cannot be deleted. Other operations are not affected.
Enabling or Disabling Modification Protection
- Switch to the Summary tab and click Configure next to Modification Protection.
- In the Configure Modification Protection dialog box, enable or disable Modification Protection.
Fill in the reason if needed.
- Click OK.
- After modification protection is enabled, you cannot modify or delete the load balancer. Other operations are not affected.
Reference
