Binding a Global Internet Gateway to a Global EIP
This section describes how to bind a global internet gateway to a global EIP. When you bind a global EIP to an ECS, the system automatically lists the global internet gateway of the VPC that the ECS belongs to, if there is one.
A global internet gateway has been created for the VPC of the ECS. If there is no global internet gateway, create one by referring to Creating a Global Internet Gateway.
- Go to the global EIP list page.
- In the global EIP list, search for or locate the target global EIP.
- Locate the target global EIP, and click Bind Instance in the Progress column.
The page for binding an instance is displayed.
- Select the region that the instance to be bound is located.
- Select the type of the instance to be bound and then select the instance.
- Select the global internet gateway to be bound.
- Click Next.
You can select an existing global connection bandwidth or purchase a new one.
- Click Finish.
