Help Center/ Elastic IP/ User Guide/ Global Elastic IP User Guide/ Global Internet Gateways/ Managing a Global Internet Gateway
Updated on 2025-08-26 GMT+08:00
You can perform the following operations to manage your global internet gateways:
Notes and Constraints
- You cannot modify parameters such as subnet and more. If you want your global internet gateway to work in another subnet, delete it and create another global internet gateway.
- A global internet gateway cannot be deleted if its attached VPC has instances (such as ECSs) with global EIPs bound. To delete such a global internet gateway, unbind the global EIPs from the instances first by referring to Unbinding a Global EIP from an Instance.
Modifying a Global Internet Gateway
- Go to the global internet gateway list page.
- In the global internet gateway list, search for or locate the target global internet gateway.
- Change the name of the global internet gateway.
Deleting a Global Internet Gateway
- Locate the row that contains the target global internet gateway and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Click OK.
