Creating a Global Internet Gateway
This section describes how to create a global internet gateway. A global internet gateway is used to connect the VPC where an ECS resides to the global EIP of the ECS. Global internet gateways are free of charge.
Notes and Constraints
Each VPC can only have one global internet gateway attached.
- Go to the global internet gateway list page.
- In the upper right corner of the page, click Create Global Internet Gateway.
The Create Global Internet Gateway is displayed.
- Configure the parameters based on Table 1.
Table 1 Parameter descriptions Parameter
Example Value
Name
Mandatory
Enter the name of the global internet gateway. The name:- Must contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
igw-89ad
Version
- IPv4: Mandatory
- IPv6: Optional
IPv4
VPC
Mandatory
Select the VPC of your instance (such as ECS) that needs to communicate with the Internet to bind the global internet gateway.
A global internet gateway is used to work together with the global EIP of your instance for Internet access.
Subnet
Mandatory
Select the subnet where you want to bind the global internet gateway.
Default Route
Optional
- If you select this option, the default route with the destination 0.0.0.0/0 will be automatically added to the default route table of the selected VPC to direct traffic to the global internet gateway.
- If you do not select this option, you need to manually add a route to the route table (default or custom) associated with the VPC subnet of your ECS to direct traffic to the global internet gateway.
- Click OK.
Related Operations
After a global EIP is bound to an instance, a global internet gateway is required so that the instance can access the Internet through the global EIP. For details, see Binding a Global Internet Gateway to a Global EIP.
