Global Internet Gateway Overview
Before binding a global EIP to an ECS, you need to create a global internet gateway to connect the VPC of the ECS to the global EIP so that the ECS can access the Internet through the global EIP. Global internet gateways are free of charge. This function is available only in certain regions. You can check the regions on the console.
When you bind a global EIP to an ECS, the system automatically lists the global internet gateway of the VPC that the ECS belongs to, if there is one.
If a global EIP is bound to a load balancer, you do not need to create a global internet gateway for the VPC that the load balancer belongs to.
Global Internet Gateway Quotas
Each VPC can only have one global internet gateway attached.
Notes and Constraints
After a global internet gateway is purchased, you cannot modify parameters such as subnet and more. If you want your global internet gateway to work in another subnet, delete it and create another global internet gateway.
Binding a Global Internet Gateway to a Global EIP
| No. | What You Need to Do | Description |
| 1 | The global Internet gateway and the instance (for example, ECS) to be bound are in the same VPC. | |
| 2 | To enable an ECS to communicate with the Internet through a global EIP, you also need to bind a global internet gateway to the global EIP. |
Related Operations
- Binding a Global Internet Gateway to a Global EIP: After a global EIP is bound to an ECS, you need to bind a global internet gateway to the global EIP so that the ECS can access the Internet through the global EIP.
- Unbinding a Global Internet Gateway from a Global EIP: When you unbind a global EIP from an ECS, the system automatically unbinds the global internet gateway of the VPC that ECS belongs to from the global EIP.
- Managing a Global Internet Gateway: You can modify or delete a global internet gateway as required.
