Adding Global EIPs to a Global Internet Bandwidth
This section describes how to add global EIPs to a global internet bandwidth. Only after this, the instances with the global EIPs bound can access the Internet.
Notes and Constraints
- You can add multiple global EIPs to a global internet bandwidth.
- The global EIPs must have the same access information, including geographic region, geographic area, access point, and type, as their global internet bandwidth.
- Go to the global internet bandwidth list page.
- In the global internet bandwidth list, search for or locate the target bandwidth.
- You can use either of the following methods to add a global EIP to a global internet bandwidth:
- Method 1:
- In the global internet bandwidth list, locate the row that contains the target global internet bandwidth, and click Add Global EIP in the Operation column.
The Add Global EIP page is displayed.
- Select one or more global EIPs and click OK.
In the global internet bandwidth list, the number of global EIPs of the bandwidth increased.
- Method 2:
- In the global internet bandwidth list, click the name of the target global internet bandwidth.
- Click the Global EIPs tab and then click Add.
The selected global EIPs are displayed on the global EIP list.
- Method 1:
