Buying a Global Internet Bandwidth
This section describes how to buy a global internet bandwidth.
If you want to buy a global internet bandwidth, submit a service ticket to apply for permissions.
- Go to the Buy Global Internet Bandwidth page.
- Configure the parameters based on Table 1.
Table 1 Parameter descriptions Parameter
Example Value
Region
Mandatory
A global internet bandwidth can only be shared by global EIPs from its same region.
For details about regions, see Selecting a Region.
CN-East
City
Mandatory
A global internet bandwidth can only be shared by global EIPs from its same city.
Shanghai
Type
Mandatory The types vary according to the selected city.
You can select:
- Static BGP
- Dynamic BGP
- CU
- CM
- CT
Dynamic BGP
Billing Mode
You can select:
- Pay-per-use
- Yearly/Monthly
The billing modes vary according to the selected city.
Pay-per-use
Bandwidth Type
You can select:
- Standard
- IPv6 Static Bandwidth
The bandwidth types vary according to the selected city.
Standard
Billed By
You can select:- Bandwidth
- 95th percentile bandwidth (standard)
The billing options vary according to the selected city.
Guaranteed Bandwidth
This parameter is available only when Billing Mode is set to Pay-per-use. The system automatically generates the guaranteed bandwidth percentage based on what you select for Billed By.
0%
Bandwidth (Mbit/s)
Mandatory
Select the size of the bandwidth. The unit is Mbit/s.
100
Global Internet Bandwidth Name
Optional
Enter the name of the bandwidth. The name:- Must contain 0 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
ibw-test
Enterprise Project
The enterprise project that the global internet bandwidth belongs to.
An enterprise project facilitates project-level management and grouping of cloud resources and users. The default project is default.
For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
default
Tag
Global internet bandwidth tag, which consists of a key and value pair.
The tag key and value must meet the requirements listed in Table 2.
- Key: geip_1.1
- Value: 10
Supplementary information about the global internet bandwidth. This parameter is optional.
Required Duration
The duration for which the yearly/monthly global internet bandwidth will be used.
1 month
Upon Expiration
This parameter must be specified if the Billing Mode is set to Yearly/Monthly. The value can be one of the following:
- Change to pay-per-use
- Auto-renew
- Enter grace period
Table 2 Tag naming rules Parameter
Requirement
Example Value
Key
- Cannot be left blank.
- Must be unique for a global internet bandwidth.
- Can contain a maximum of 36 characters.
- Can contain letters, digits, underscores (_), and hyphens (-).
geip_1.1
Value
- Can contain a maximum of 43 characters.
- Can contain letters, digits, underscores (_), periods (.), and hyphens (-).
10
- Click Next.
- Confirm the configurations and click Submit.
The global internet bandwidth list page is displayed.
- In the global internet bandwidth list, view the status of the bandwidth.
If the status of the bandwidth is Normal, the purchase is successful.
Follow-Up Procedure
If your instance with a global EIP bound needs to access the Internet, you also need to add the global EIP to a global internet bandwidth. For details, see Adding Global EIPs to a Global Internet Bandwidth.
