Updated on 2025-08-26 GMT+08:00
Monitoring Metrics
Overview
This section describes the namespace, list, and measurement dimensions of metrics of global EIPs and global internet bandwidths that you can check on Cloud Eye. You can use APIs or the Cloud Eye console to query the metrics of the monitored metrics and generated alarms.
Namespace
Namespace of global EIPs and global internet bandwidths: SYS.GEIP
Monitoring Metrics
Table 1 Global EIP and global internet bandwidth metrics
ID
Name
Value Range
Unit
Conversion Rule
Monitored Object (Dimension)
Monitoring Interval (Raw Data)
upstream_bandwidth
Outbound bandwidth
Network rate of outbound traffic (Previously called "Upstream Bandwidth")
≥ 0
bit/s
1000 (SI)
Global EIP or global internet bandwidth
1 minute
downstream_bandwidth
Inbound bandwidth
Network rate of inbound traffic (Previously called "Downstream Bandwidth")
≥ 0
bit/s
1000 (SI)
1 minute
upstream_bandwidth_usage
Outbound Bandwidth Usage
Usage of outbound bandwidth in the unit of percent.
Outbound bandwidth usage = Outbound bandwidth/Purchased bandwidth
0-100
N/A
1 minute
downstream_bandwidth_usage
Inbound Bandwidth Usage
Usage of inbound bandwidth in the unit of percent.
Inbound bandwidth usage = Inbound bandwidth/Purchased bandwidth
0-100
N/A
1 minute
up_stream
Outbound Traffic
Network traffic going out of the cloud platform (Previously called "Upstream Traffic")
≥ 0
Bytes
1000 (SI)
1 minute
down_stream
Inbound Traffic
Network traffic going into the cloud platform (Previously called "Downstream Traffic")
≥ 0
Bytes
1000 (SI)
1 minute
If a bandwidth is increased or decreased, there is a delay of 5 to 10 minutes for the monitoring metrics to update for the new bandwidth.
Dimensions
Key
Value
If a monitored object has multiple dimensions, all dimensions are mandatory when you use APIs to query the metrics.
  • Query a monitoring metric: dim.0=geip_internet_bandwidth_id,530cd6b0-86d7-4818-837f-935f6a27414d&dim.1=geip_global_eip_id,3773b058-5b4f-4366-9035-9bbd9964714a
  • Query monitoring metrics in batches:
    "dimensions": [
    "name": "geip_internet_bandwidth_id",
    "value": "530cd6b0-86d7-4818-837f-935f6a27414d"
    "name": "geip_global_eip_id",
    "value": "3773b058-5b4f-4366-9035-9bbd9964714a"
