Binding a Global EIP to an Instance
This section describes how to bind a global EIP to an instance, such as an ECS or a load balancer, to enable the instance to communicate with the Internet through the global EIP.
By default, a global EIP can be bound to instances in the same geographic region. To bind a global EIP to an instance in another geographic region, submit a service ticket.
- A global EIP can be bound to only one instance at a time.
- After a global EIP is bound to an ECS, the VPC of the ECS cannot be changed, and no more EIP can be bound to the ECS.
- A global EIP cannot be bound to a shared load balancer.
- The required instance (such as ECS or ELB) has been created.
- For an ECS, you also need to create a global internet gateway for the VPC that the ECS belongs to.
- Go to the global EIP list page.
- In the global EIP list, search for or locate the target global EIP.
- Locate the target global EIP, and click Bind Instance in the Progress column.
The page for binding an instance is displayed.
- Select the region that the instance to be bound is located.
- Select the type of the instance to be bound and then select the instance.
- Select the global internet gateway to be bound.
The system automatically lists the global internet gateway of the VPC that the instance belongs to, if there is one.
- Click Next.
- Configure Global Connection Bandwidth, Bandwidth Name, and Bandwidth as prompted.
If there is no global connection bandwidth, click Manage Global Connection Bandwidth to create one. For details, see Buying a Global Connection Bandwidth.
- Click OK.
In the global EIP list, you can see that the global EIP has instance bound.
Related Operations
- (Mandatory) After a global EIP is bound to an instance, you need to bind a global connection bandwidth to the global EIP. For details, see Adding Instances to a Global Connection Bandwidth.
- You need to create a global internet gateway for the VPC of the ECS. For details, see Creating a Global Internet Gateway.
