Updated on 2025-08-26 GMT+08:00
Assigning a Global EIP
This section describes how to assign a global EIP. Global EIPs can be bound to cloud instances (such as ECSs or load balancers) from any region so that these instances can access the Internet. You can specify the access point, type, and global EIP pool based on your service requirements on Internet access.
If you want to assign a global EIP, submit a service ticket to apply for permissions.
  1. Go to the Assign Global EIP page.
  2. Configure the parameters based on Table 1.
    Table 1 Parameter descriptions
    Example Value
    Region
    Mandatory
    For details about regions, see Selecting a Region.
    CN East-Shanghai1
    City
    Mandatory
    A global internet bandwidth can only be shared by global EIPs from its same city.
    Shanghai
    Type
    Select Global EIP or Global EIP range.
    Global EIP
    Version
    Select IPv4 or IPv6.
    IPv4
    Global EIP Type
    Mandatory
    • You can select:
      • Static BGP
      • Dynamic BGP
      Reverse resolution is not supported for static single-line IP addresses (non-cloud vendor IP addresses).
    • After you select a global EIP pool, the system will allocate a global EIP to you from the pool. Select a resource pool close to your business to minimize the latency.
    Mask Length
    This parameter is available only when Type is set to Global EIP range. You can call the following API obtain all available mask lengths:
    GET /v3/{domain_id}/global-eip-segments/support-masks
    24
    Global Internet Bandwidth
    Mandatory
    • Assign now: Select this option if you want to purchase a new global internet bandwidth.
    • Use existing: Select this option if you want to add the global EIP to an existing global internet bandwidth for internet access.
    Billing Mode
    You can select:
    • Yearly/Monthly
    • Pay-per-use
    Pay-per-use
    Bandwidth Type
    You can select:
    • Standard
    • IPv6 Static Bandwidth
    Standard
    Billed By
    This parameter is available only when Billing Mode is set to Pay-per-use. You can select:
    • 95th percentile bandwidth (standard)
    • 95th percentile bandwidth (bidirectional)
    Guaranteed Bandwidth
    This parameter is available only when Billing Mode is set to Pay-per-use. The system automatically generates the guaranteed bandwidth percentage based on what you select for Billed By.
    0%
    Bandwidth (Mbit/s)
    The bandwidth size in Mbit/s.
    300
    Global EIP Name
    Optional
    Enter the name of the global EIP. The name:
    • Must contain 0 to 64 characters.
    • Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    g-eip01
    Enterprise Project
    The enterprise project that the global EIP belongs to.
    An enterprise project facilitates project-level management and grouping of cloud resources and users. The default project is default.
    For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
    default
    Advanced Settings
    Click the drop-down arrow to configure parameters, including the bandwidth name and tag.
    Retain the default settings.
    Bandwidth Name
    Optional
    Enter the name of the bandwidth. The name:
    ibw-test
    Tag
    Global EIP tag, which consists of a key and value pair.
    The tag key and value must meet the requirements listed in Table 2.
    • Key: geip_1
    • Value: 184.100.101.102
    Monitoring
    This function is free. With Cloud Eye, you can monitor:
    • Network traffic at one-minute intervals.
    • Bandwidth fluctuations and inbound and outbound bandwidth rates.
    Quantity
    This parameter is available only when Type is set to Global EIP. Number of global EIPs to be assigned.
    3
    Required Duration
    The duration for which the yearly/monthly global EIP will be used.
    1 month
    Upon Expiration
    This parameter must be specified if the Billing Mode is set to Yearly/Monthly. The value can be one of the following:
    • Change to pay-per-use
    • Auto-renew
    • Enter grace period
    Table 2 Naming rules for global EIP tags
    Requirement
    Example Value
    Key
    • Cannot be left blank.
    • Must be unique for a global EIP.
    • Can contain a maximum of 128 characters.
    • Can contain letters, digits, underscores (_), and hyphens (-). Cannot start with _sys_ or a space or end with a space.
    geip_1
    Value
    • Can contain a maximum of 255 characters.
    • Can contain letters, digits, underscores (_), periods (.), hyphens (-), and cannot start or end with a space.
    184.100.101.102
  3. Click Next.
  4. Confirm the configurations and click Submit.
    The global EIP list is displayed.
  5. In the global EIP list, view the global EIP status.
    If the status of the global EIP is Unbound, the EIP is assigned successfully.
Related Operations
