Updated on 2025-09-30 GMT+08:00
Renewing a Yearly/Monthly EIP
You can renew a yearly/monthly EIP to extend its expiration date.
If your yearly/monthly resource is expired and is not renewed, the resource enters the grace period. If you do not renew the yearly/monthly resource within the grace period, the resource enters a retention period after the grace period has expired. You cannot perform any operations on yearly/monthly resources that are in the grace or retention period. For example, you cannot change your bandwidth if it is in the grace period or retention period.
This section describes how to renew an EIP. Renewing EIPs does not change EIPs.
  1. Go to the EIP list page.
  2. In the EIP list, renew a single EIP or multiple EIPs.
    • Renewing a single EIP:
      Locate the row that contains the EIP, and choose More > Renew in the Operation column.
    • Renewing multiple EIPs at once:
      1. Select the EIPs in the EIP list and click Renew in the upper left corner of the list.
      2. In the displayed dialog box, confirm the information and click Yes.
  3. On the Renew page, set the following parameters:
    • Renewal Duration: Select a renewal period as required.
    • Renewal Date: The new renewal date may result in slightly different subscription lengths for different resources.
  4. Click Pay.
