IPv6 EIP Overview
Overview
Both IPv4 and IPv6 EIPs are available. You can map an existing IPv4 EIP to an IPv6 EIP.
After the IPv6 EIP function is enabled, you will obtain both an IPv4 EIP and its corresponding IPv6 EIP. External IPv6 addresses can access cloud resources through this IPv6 EIP.
IPv4 EIPs are billed. IPv6 EIPs are currently free, but will be billed at a later date (price yet to be determined).
Application Scenarios of IPv4/IPv6 Dual Stack
If your ECS supports IPv6, you can use the IPv4/IPv6 dual stack. For details about application scenarios and resource planning, see Table 1.
If the value of IPv6 is Yes for an ECS flavor, the flavor supports IPv6.
AZ and Flavor determine whether IPv6 is supported.
After you select an AZ, if IPv6 is not displayed or the value of IPv6 is No, IPv6 is not supported by any or certain flavors in the AZ.
Applicable Scenario |
Description |
Requirement |
IPv4 or IPv6 Subnet |
ECS |
Private IPv4 communication |
Your applications on ECSs need to communicate with other systems (such as databases) through private networks using IPv4 addresses. |
IPv4 CIDR block |
Private IPv4 address: used for private IPv4 communication. |
Public IPv4 communication |
Your applications on ECSs need to communicate with other systems (such as databases) through public IPv4 addresses. |
IPv4 CIDR block |
Private IPv6 communication |
Your applications on ECSs need to communicate with other systems (such as databases) through private IPv6 addresses. |
Public IPv6 communication |
An IPv6 network is required for the ECS to access the IPv6 service on the Internet. |
For details, see Setting Up an IPv6 Network. |
For details, see IPv4 and IPv6 Dual-Stack Network.
Application Scenarios of IPv6 EIP
If you want an ECS to provide IPv6 services but the ECS does not support IPv6 networks or you do not want to build an IPv6 network, you can use IPv6 EIP to quickly address your requirements. For details about application scenarios and resource planning, see Table 2.
Description |
Requirement |
ECS |
You want to allow an ECS to provide IPv6 services for clients on the Internet without setting up an IPv6 network. |
IPv4 CIDR block |
Application Scenarios and Resource Planning of IPv6 Networks
