Updated on 2025-08-26 GMT+08:00
Managing EIP Pools
You can perform the following operations to manage your EIP pools:
Modifying the Quota of EIPs in an EIP Pool
  1. Go to the EIP pool list page.
  2. Locate the row that contains the EIP pool to be modified and click Modify in the Operation column. On the displayed Modify EIP Pool page, modify the EIP quota.
    You can decrease or increase the quota as required. The change is applied immediately.
    • Decreasing the EIP quota
      1. Select or enter a lower quota and click Next.
      2. Confirm the configuration and submit your request.
    • Increasing the EIP quota
      1. Select or enter a higher quota and click Next.
      2. Confirm the configuration and click Pay Now.
      3. On the payment page, select a payment method and click Confirm.
Renewing an EIP Pool
  2. Locate the EIP pool to be renewed and click Renew in the Operation column.
  3. On the Renew page, set the renewal duration.
  1. Set Renewal Date.
    The new renewal date may extend the subscription based on the current subscription. You can check the renewal information in the table on the Renew page.
  2. On the payment page, confirm the order information and click Confirm.
Unsubscribing From an EIP Pool
  2. Locate the EIP pool you want to unsubscribe from and click Unsubscribe in the Operation column.
  3. On the Unsubscribe from Resource page, click Confirm.
