- What's New
- Function Overview
- Billing
- Getting Started
User Guide
Elastic IP User Guide
- Permissions Management
- Elastic IP
- IPv6 EIP
- EIP Billing
- EIP Pool
- Shared Bandwidth
- Resource Package
- Cloud Eye Monitoring
- Managing EIP Quotas
- Global Elastic IP User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- API V3
- Native OpenStack Neutron APIs V2.0
- Application Examples
- Appendix
- SDK Reference
Product Consultation
- Managing Quotas
- How Do I Assign or Retrieve a Specific EIP?
- Why Is an EIP Newly Assigned the Same as the One I Released?
- Can I Buy a Specific EIP?
- Does an EIP Change Over Time?
- Why Can't I Find My Purchased EIP on the Management Console?
- What Is the EIP Assignment Policy?
- Can an EIP Be Used or Migrated Across Accounts?
- How Do I Query the Traffic Usage of My EIP?
- Do I Need to Configure a Shared Data Package for Use After It Is Purchased?
- Can I Change the Dedicated Bandwidth Used by an EIP to a Shared Bandwidth?
- How Many ECSs Can I Bind an EIP To?
- What Are the Differences Between EIP, Private IP Address, and Virtual IP Address?
- What Are the Differences Among a Bandwidth Add-On Package, Shared Data Package, and Shared Bandwidth?
- When Should I Use Premium BGP and Are There Any Limitations on Using Premium BGP?
- Why My EIPs Are Frozen? How Do I Unfreeze My EIPs?
Billing and Payments
- How Is an EIP Billed?
- How Do I Change My EIP Billing Mode Between Pay-per-Use and Yearly/Monthly?
- How Do I Change the Billing Option of a Pay-per-Use EIP Between By Bandwidth and By Traffic?
- Why Am I Still Being Billed After My EIP Has Been Unbound or Released?
- When Will I Be Billed for Reservation Price?
EIP Binding and Unbinding
- How Do I Access an ECS with an EIP Bound from the Internet?
- How Can I Unbind an Existing EIP from an Instance and Bind Another EIP to the Instance?
- Can I Bind an EIP of an ECS to Another ECS?
- Can I Bind an EIP to a Cloud Resource in Another Region?
- Can Multiple EIPs Be Bound to an ECS?
- What Are the Differences Between Unbinding and Releasing an EIP?
Bandwidth
- How Do I Increase a Bandwidth to Be More Than 300 Mbit/s?
- What Bandwidth Types Are Available?
- How Many EIPs Can I Add to Each Shared Bandwidth?
- What Are the Differences Between a Dedicated Bandwidth and a Shared Bandwidth?
- What Are Inbound Bandwidth and Outbound Bandwidth?
- How Do I Know If My EIP Bandwidth Has Been Exceeded?
- What Are the Differences Between Public Bandwidth and Private Bandwidth?
- Can I Increase a Yearly/Monthly Bandwidth and Decrease It Later?
- What Is the Relationship Between Bandwidth and Upload/Download Rate?
- What Are the Differences Among Static BGP, Dynamic BGP, and Premium BGP?
Connectivity
- What Are the Priorities of the Custom Route and EIP If Both Are Configured for an ECS to Enable the ECS to Access the Internet?
- Why Can't My ECS Access the Internet Even After an EIP Is Bound?
- What Should I Do If an EIP Cannot Be Pinged?
- How Do I Unblock an EIP?
- Why Is There Network Jitter or Packet Loss During Cross-Border Communications?
- Why Does the Download Speed of My ECS Is Slow?
- Videos
- Glossary
More Documents
- Quick Start
- EIP Overview
- Assigning an EIP and Binding It to an ECS
- Assigning an EIP
- Binding an EIP to an Instance
- Unbinding an EIP from an Instance
- Releasing an EIP
- Changing Dedicated Bandwidth Size of an EIP
- Unbinding an EIP from an ECS and Releasing the EIP
- Modifying an EIP Bandwidth
- Exporting EIP Information
- Managing EIP Tags
- Shared Bandwidth
- Monitoring
- What Is a Quota?
- Can an EIP That Uses Dedicated Bandwidth Be Changed to Use Shared Bandwidth?
- Can I Bind an EIP to Multiple ECSs?
- What Are the Differences Between the Primary and Extension NICs of ECSs?
- Can I Assign a Specific EIP?
- Can a Bandwidth Be Used by Multiple Accounts?
- How Do I Unbind an EIP from an Instance and Bind a New EIP to the Instance?
- Why Can't I Find My Assigned EIP on the Management Console?
- EIP Binding and Unbinding
Bandwidth
- What Is the Bandwidth Size Range?
- Is There a Limit to the Number of EIPs That Can Be Added to Each Shared Bandwidth?
- How Do I Know If My EIP Bandwidth Limit Has Been Exceeded?
- Connectivity
- Change History
- API Reference (ME-Abu Dhabi Region)
- Quick Start
- EIP
- Shared Bandwidth
- Monitoring
- Product Consultation
Bandwidth
- What Are the Differences Between a Dedicated Bandwidth and a Shared Bandwidth? Can a Dedicated Bandwidth Be Changed to a Shared Bandwidth or the Other Way Around?
- Connectivity
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
On this page
QoS
You can enable or disable QoS as required. You can configure or cancel bandwidth limits for each EIP using a shared bandwidth.
Notes and Constraints
- QoS can only be enabled when the shared bandwidth is at least equal to 50 Mbit/s.
- The maximum guaranteed bandwidth can be 2000 Mbit/s.
- The sum of guaranteed bandwidths that you configured for the EIPs in a shared bandwidth cannot exceed the shared bandwidth.
- If the size of a shared bandwidth is decreased (such as its bandwidth add-on package expires), the guaranteed bandwidth and the maximum bandwidth of the EIPs that use the shared bandwidth may be adversely affected.
- The bandwidth limit will be disabled when the bandwidth add-on package used by the shared bandwidth expires.
Enabling QoS
- Assign a shared bandwidth by referring to Assigning a Shared Bandwidth and select the QoS option.
Figure 1 Selecting the QoS option
- In the shared bandwidth list, locate the row that contains the shared bandwidth, click More in the Operation column, and click Enable QoS.
Disabling QoS
In the shared bandwidth list, locate the target shared bandwidth, click More in the Operation column, and click Disable QoS.
Configuring or Canceling Bandwidth Limits
- Go to the shared bandwidth list page.
- In the shared bandwidth list, click the name of the target shared bandwidth.
- On the EIPs or IPv6 Addresses tab page, configure or cancel bandwidth limits as required.
- Configuring bandwidth limit
- Locate the target EIP or IPv6 address and click Configure Bandwidth Limit in the Operation column.
- Set Guaranteed Bandwidth and Maximum Bandwidth.
- Click OK.
- Canceling bandwidth limit
- Locate the target EIP or IPv6 address and click Cancel Bandwidth Limit in the Operation column.
- Click OK.
Parent Topic: Shared Bandwidth
