- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
On this page
Show all
Introduction
Event sources include Huawei Cloud services, custom applications, and SaaS applications. They produce events and publish them to EG.
EG supports the following event sources:
- Cloud service: Huawei Cloud services publish specific types of events to EG through predefined channels. The events are filtered with rules and then routed to targets. For details about the supported cloud service event sources, see Cloud Service Event Sources.
- Custom
- Custom applications publish events to EG through custom channels. The events are filtered with rules and then routed to targets.
- Custom event sources include DMS for RabbitMQ and DMS for RocketMQ.
EG does not encrypt the information in event sources. If your events contain sensitive information, encrypt it for security.
Parent topic: Event Sources
