Updated on 2025-09-15 GMT+08:00
DDoS Attack Logs
You can view attack logs of all protected domain names in the last 7 days.
A protected website has been added. For details, see Adding a Website to EdgeSec.
  1. Log in to the EdgeSec console.
  2. In the navigation pane on the left, choose Edge Security > Statistic. On the displayed Statistic page, click the DDoS Attack Logs tab.
  3. On the DDoS Attack Logs tab page, view protection logs of yesterday, today, past 3 days, past 7 days, or a custom time range.
    Auto Refresh: After the function is enabled, the data is refreshed every 30 seconds.
  4. In the event list, view the event details.
    • Select a filtering criterion or enter a keyword to search for specific events.
    • Click to select fields you want to display in the event lists.
    Figure 1 Event list
    Table 1 Parameters in the event list
    avg_bps
    Average bandwidth of DDoS attack traffic.
    max_bps
    Maximum bandwidth of DDoS attack traffic.
    avg_pps
    Average forwarding rate of data packets.
    max_pps
    Maximum forwarding rate of data packets.
    ddos attack time
    Time when a DDoS attack occurs.
  5. Click Export in the upper left corner to export all attack logs to an XLSX file.
