Help Center/ Edge Security/ User Guide/ Protection Statistics/ Viewing the DDoS Attack Monitoring Trend
Updated on 2025-12-17 GMT+08:00
After a service is connected, you can view the protection information to learn about the security status of the current service.
If you have enabled enterprise projects, you can select your enterprise project from the Enterprise Project drop-down list and view the protection information of the project.
  1. Log in to the EdgeSec console.
  2. In the navigation pane on the left, choose Edge Security > Statistic. On the displayed Statistic page, click the DDoS Attack Monitoring tab.
  3. In the upper right corner of the displayed page, select a time range to view the trend chart of yesterday, today, 3 days, 7 days, or 30 days.
    Auto Refresh: After the function is enabled, the data is refreshed every 30 seconds.
  4. View the DDoS attack monitoring trend chart. For details about the parameters, see DDoS attack event statistics parameters.
    Figure 1 DDoS attack monitoring trend chart
    Table 1 DDoS attack event statistics parameters
    Peak bandwidth
    Maximum bandwidth at the current time point.
    Average bandwidth.
    Average bandwidth at the current time point.
    Peak packet sending rate
    Maximum packet sending rate at the current time point.
    Average packet sending rate
    Average packet sending rate at the current time point.
