Help Center/ Elastic Cloud Server/ User Guide/ Security/ Security Groups/ Security Group Configuration Examples
Updated on 2025-02-19 GMT+08:00
When you create instances, such as cloud servers, containers, and databases, in a VPC subnet, you can use the default security group or create a security group. You can add inbound and outbound rules to the default or your security group to control traffic from and to the instances in the security group. Here are some common security group configuration examples:
NOTICE:
If your security group rules are not applied, submit a service ticket.
Precautions
Note the following before configuring security group rules:
  • Instances associated with different security groups are isolated from each other by default.
  • Generally, a security group denies all external requests by default, while allowing instances in it to communicate with each other.
    If required, you can add inbound rules to allow specific traffic to access the instances in the security group.
  • If the source is set to 0.0.0.0/0 or::/0, then the access from all external IP addresses are either allowed or denied, depending on if the action is Allow or Deny. If the access is allowed, exposing high-risk ports, such as port 22, 3389, or 8848, to the public network will leave your instances vulnerable to network intrusions, service interruptions, data leakage, or ransomware attacks. You should only configure trusted IP addresses for the security group rule.
  • By default, outbound security group rules allow all requests from the instances in the security group to access external resources.
    If outbound rules are deleted, the instances in the security group cannot communicate with external resources. To allow outbound traffic, you need to add outbound rules by referring to Table 1.
    Table 1 Default outbound rules in a security group
    Direction
    Priority
    Action
    Type
    Protocol & Port
    Destination
    Outbound
    Allow
    IPv4
    All
    0.0.0.0/0
    Allows the instances in the security group to access any IPv4 address over any port.
    Outbound
    Allow
    IPv6
    All
    ::/0
    Allows the instances in the security group to access any IPv6 address over any port.
Remotely Logging In to an ECS from a Local Server
A security group denies all external requests by default. To remotely log in to an ECS in a security group from a local server, add an inbound rule based on the OS running on the ECS.
  • To remotely log in to a Linux ECS using SSH, enable port 22. For details, see Table 2.
  • To remotely log in to a Windows ECS using RDP, enable port 3389. For details, see Table 3.
    Table 2 Remotely logging in to a Linux ECS using SSH
    Direction
    Priority
    Action
    Type
    Protocol & Port
    Source
    Inbound
    Allow
    IPv4
    TCP: 22
    IP address: 0.0.0.0/0
    Table 3 Remotely logging in to a Windows ECS using RDP
    Direction
    Priority
    Action
    Type
    Protocol & Port
    Source
    Inbound
    Allow
    IPv4
    TCP: 3389
    NOTICE:
    If the source is set to 0.0.0.0/0, all external IP addresses are allowed to remotely log in to the ECS. To ensure network security and prevent service interruptions caused by network intrusions, set the source to a trusted IP address. For details, see Table 4.
    Table 4 Remotely logging in to an ECS using a trusted IP address
    ECS Type
    Direction
    Priority
    Action
    Type
    Protocol & Port
    Source
    Linux ECS
    Inbound
    Allow
    IPv4
    TCP: 22
    IP address: 192.168.0.0/24
    Windows ECS
    Inbound
    Allow
    IPv4
    TCP: 3389
    IP address: 10.10.0.0/24
Remotely Connecting to an ECS from a Local Server to Upload or Download Files over FTP
By default, a security group denies all external requests. If you need to remotely connect to an ECS from a local server to upload or download files over FTP, you need to enable FTP ports 20 and 21.
Table 5 Remotely connecting to an ECS from any server to upload or download files over FTP
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
IPv4
TCP: 20-21
NOTICE:
  • If the source is set to 0.0.0.0/0, all external IP addresses are allowed to remotely log in to the ECS to upload or download files. To ensure network security and prevent service interruptions caused by network intrusions, set the source to a trusted IP address. For details, see Table 6.
  • You must first install the FTP server program on the ECSs and then check whether ports 20 and 21 are working properly.
Table 6 Remotely connecting to an ECS from a trusted server to upload or download files
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
IPv4
TCP: 20-21
Setting Up a Website on an ECS to Provide Internet-Accessible Services
A security group denies all external requests by default. If you set up a website on an ECS to allow access from the Internet, you need to add an inbound rule to the ECS security group to allow access over specific ports, such as HTTP (80) and HTTPS (443).
Table 7 Setting up a website on an ECS to provide services internet-accessible services
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
IPv4
TCP: 80
Inbound
Allow
IPv4
TCP: 443
Using ping Command to Verify Network Connectivity
Ping works by sending an Internet Control Message Protocol (ICMP) Echo Request. To ping an ECS from your PC to verify the network connectivity, you need to add an inbound rule to the security group of the ECS to allow ICMP traffic.
Table 8 Using ping command to verify network connectivity
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
IPv4
ICMP: All
Inbound
Allow
IPv6
ICMP: All
IP address: ::/0
Enabling Communications Between Instances in Different Security Groups
Instances in the same VPC but in different security groups cannot communicate with each other. If you want ECSs in security group sg-A to access MySQL databases in security group sg-B, you need to add an inbound rule to security group sg-B to allow access from ECSs in security group sg-A.
Table 9 Enabling communications between instances in different security groups
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
IPv4
TCP: 3306
Security group: sg-A
NOTICE:
In the example in "Allowing Traffic from a Virtual IP Address" in How Security Groups Are Used, two ECSs in Subnet-A and Subnet-B are connected by a virtual IP address. If you set the source of inbound rules to the security groups associated with the ECSs, the ECSs in the two security groups cannot communicate with each other. To enable communications between them, set the source to the private IP address or subnet CIDR block of the virtual IP address.
Allowing External Instances to Access the Database Deployed on an ECS
A security group denies all external requests by default. If you have deployed a database on an ECS and want the database to be accessed from external instances on a private network, you need to add an inbound rule to the security group of the ECS to allow access over corresponding ports. Here are some common ports for databases:
  • MySQL: port 3306
  • Oracle: port 1521
  • MS SQL: port 1433
  • PostgreSQL: port 5432
  • Redis: port 6379
Table 10 Allowing external instances to access the database deployed on an ECS
Direction
Priority
Action
Type
Protocol & Port
Source
Inbound
Allow
IPv4
TCP: 3306
Allows the ECSs in security group sg-A to access the MySQL database.
Inbound
Allow
IPv4
TCP: 1521
Security group: sg-B
Allows the ECSs in security group sg-B to access the Oracle database.
Inbound
Allow
IPv4
TCP: 1433
IP address: 172.16.3.21/32
Allows the ECS whose private IP address is 172.16.3.21 to access the MS SQL database.
Inbound
Allow
IPv4
TCP: 5432
Allows ECSs whose private IP addresses are in the 192.168.0.0/24 network to access the PostgreSQL database.
Inbound
Allow
IPv4
TCP: 6379
IP address group: ipGroup-A
Allows ECSs whose private IP addresses are in IP address group ipGroup-A to access the Redis database.
NOTICE:
In this example, the source IP addresses are for reference only. Replace them with actual IP addresses.
Allowing ECSs to Access Only Specific External Websites
By default, a security group allows all outbound traffic. Table 12 lists the default outbound rules. If you want to allow ECSs to access only specific websites, configure the security group as follows:
  1. Add outbound rules to only allow traffic over specific ports to specific IP addresses.
    Table 11 Allowing ECSs to access only specific external websites
    Direction
    Priority
    Action
    Type
    Protocol & Port
    Destination
    Outbound
    Allow
    IPv4
    TCP: 80
    IP address: 132.15.XX.XX
    Allows ECSs in the security group to access the external website at http://132.15.XX.XX:80.
    Outbound
    Allow
    IPv4
    TCP: 443
    IP address: 145.117.XX.XX
    Allows ECSs in the security group to access the external website at https://145.117.XX.XX:443.
  2. Delete the default outbound rules that allow all traffic.
    Table 12 Default outbound rules in a security group
    Direction
    Priority
    Action
    Type
    Protocol & Port
    Destination
    Outbound
    Allow
    IPv4
    All
    0.0.0.0/0
    Outbound
    Allow
    IPv6
    All
    ::/0
