Updated on 2025-08-28 GMT+08:00
Viewing the ECS Creation Status
After submitting the request for creating an ECS, you can view the creation status. This section describes how to view the creation status of an ECS.
  2. Click in the upper left corner and select a region and project.
  3. Click . Under Compute, click Elastic Cloud Server.
  4. View the ECS status in the Status column after purchasing an ECS.
    • An ECS is in one of the following states when it is being created:
      • Creating: The ECS is being created.
      • Faulty: Creating the ECS failed. For a failed task, the system rolls back the task and displays an error code, for example, Ecs.0013 Insufficient EIP quota.
      • Running: The request of creating the ECS has been processed, and the ECS is running properly. An ECS in this state can provide services for you.
    • If you find that the task status area shows an ECS creation failure but the ECS list displays the created ECS, see Why Does the Failures Area Show an ECS Creation Failure But the ECS List Displays the Created ECS?
