Updated on 2024-10-18 GMT+08:00
Login Overview (Linux)
  • Only a running ECS can be logged in.
  • The username for logging in to a Linux ECS is root.
  • If the login password is forgotten, reset the password on the ECS console.
    To reset a password, locate the row containing the target ECS, click More in the Operation column, and select Reset Password from the drop-down list. For details, see Resetting the Password for Logging In to an ECS on the Management Console.
Login Modes
You can choose from a variety of login modes based on your local OS type.
Table 1 Linux ECS login modes
ECS OS
Local OS
Connection Method
Requirement
Linux
Windows
(Recommended) Use CloudShell available on the management console to log in to the ECS.
Logging In to a Linux ECS Using CloudShell
The target ECS has an EIP bound.
(If you log in to an ECS through an intranet, for example, through VPN or Direct Connect, the ECS does not require an EIP.)
Windows
Use a remote login tool, such as PuTTY or Xshell.
Linux
Run commands.
Mobile terminal
Use an SSH client tool, such as Termius or JuiceSSH, to log in to the ECS.
Logging In to a Linux ECS from a Mobile Terminal
macOS
Use the terminal included in the macOS.
Logging In to a Linux ECS from a macOS Server
Windows
Use the remote login function available on the management console. For details, see Logging In to a Linux ECS Using VNC.
No EIP is required.
