Querying an Event
This section describes how to query events on the ECS console.
You can also check ECS events details on the Event Monitoring page on the Cloud Eye console. For details, see Viewing Event Monitoring Data.
If you need to perform operations as an IAM user, ensure that the IAM user has been granted the required permissions.
Event query and handling require the permissions defined in the following policies:
- Query events: ecs:instanceScheduledEvents:list
- Accept and authorize events: ecs:instanceScheduledEvents:accept
- Change the reservation time: ecs:instanceScheduledEvents:update
For details about how to grant permissions to IAM users, see Using IAM Roles or Policies to Grant Access to ECS.
- Click
in the upper left corner and select a region and project. - Click
. Under Compute, choose Elastic Cloud Server. - Choose Events from the left navigation pane.
In the displayed list on the Events page, you can view the event ID, instance name/ID, event type, and more event details.
You can perform the operations displayed in the Operation column on events. For details, see Handling an Event.
