Help Center/ Elastic Cloud Server/ User Guide/ Using IAM to Grant Access to ECS/ Using IAM Roles or Policies to Grant Access to ECS
Updated on 2026-09-21 GMT+08:00
System-defined permissions in role/policy-based authorization provided by Identity and Access Management (IAM) let you control access to ECS. With IAM, you can:
  • Create IAM users in your account for personnel based on your enterprise's organizational structure. Each IAM user has their own security credentials for accessing ECS resources.
  • Grant users only the permissions required to perform a given task based on their job responsibilities.
  • Entrust an account or a cloud service to perform efficient O&M on your ECS resources.
If your account does not require individual IAM users, you can skip this section.
Figure 1 shows the process flow of role/policy-based authorization.
Before granting permissions to user groups, learn about system-defined permissions in role/policy-based authorization for ECS. To grant permissions for other services, learn about all system-defined permissions supported by IAM.
Process Flow
Figure 1 Process of granting ECS permissions using role/policy-based authorization
  1. Create a user group and assign permissions.
    Create a user group on the IAM console and assign the ECS ReadOnlyAccess permissions to the group.
  2. Create a user and add the user to the user group.
    On the IAM console, create a user and add it to the user group created in step 1.
  3. Log in as the IAM user and verify permissions.
    In the authorized region, perform the following operations:
    • Choose Service List > Elastic Cloud Server. Then click Buy ECS on the ECS console. If a message appears indicating that you have insufficient permissions to perform the operation, the ECS ReadOnlyAccess policy is in effect.
    • Choose another service from Service List. If a message appears indicating that you have insufficient permissions to access the service, the ECS ReadOnlyAccess policy is in effect.
Example Custom Policies
You can create custom policies to supplement the system-defined policies of ECS. For details about actions supported in custom policies, see Actions Supported by Policy-based Authorization.
To create a custom policy, choose either visual editor or JSON.
  • Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
  • JSON: Create a JSON policy or edit an existing one.
For details, see Creating a Custom Policy. The following lists examples of common ECS custom policies.
  • Example 1: Grant permission to batch stop and delete ECSs.
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "ecs:cloudServers:delete",
                    "ecs:cloudServers:stop"
  • Example 2: Grant permission to deny ECS deletion.
    A policy with only "Deny" permissions must be used together with other policies. If the permissions granted to an IAM user contain both "Allow" and "Deny", the "Deny" permissions take precedence over the "Allow" permissions.
    Assume that you want to grant the permissions of the ECSFullAccess policy to a user but want to prevent them from deleting ECSs. You can create a custom policy for denying ECS deletion, and attach this policy together with the ECSFullAccess policy to the user. As an explicit deny in any policy overrides any allows, the user can perform all operations on ECSs except deleting them.
    Example policy denying ECS deletion:
          "Version": "1.1",
          "Statement": [
    		  "Effect": "Deny",
                      "Action": [
  • Example 3: Create a custom policy containing multiple actions.
    A custom policy can contain the actions of one or multiple services that are of the same type (global or project-level).
    Example policy containing multiple actions:
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "ecs:cloudServers:resize"
                "Effect": "Allow",
                "Action": [
                    "ims:serverImages:create",
                    "ims:images:list"
ECS Resources
A resource is an object that exists within a service. ECS resources include instances. To select these resources, specify their paths.
Table 1 ECS resources and their paths
Resource
Path
instance
ecs:<region>:<account-id>:instance:<server-id>
