Updated on 2025-07-25 GMT+08:00
Attaching a Network Interface
If your ECS requires multiple network interfaces, you can attach them to your ECS.
  2. Click in the upper left corner and select a region and project.
  3. Click . Under Compute, click Elastic Cloud Server.
  4. Click the name of the ECS to which you want to attach a network interface.
    The page providing details about the ECS is displayed.
  5. On the Network Interfaces tab, click Attach Network Interface.
  6. Select either of the following methods to attach the network interface.
    • Use an existing network interface.
      1. (Optional) Search for the network interface by name, ID, or private IP address.
      2. In the network interface list, select the target one.
    • Create a new network interface.
      Set the subnet and security group for the network interface to be attached.
      Figure 1 Configuring the subnet and security group
      • Subnet: the subnet that the network interface belongs to.
      • New Private IP Address: If you want to add a network interface with a specified IP address, enter an IP address into the Private IP Address field.
      • Security Group: You can select multiple security groups. In such a case, the access rules of all the selected security groups will apply to the ECS.
  7. Click OK.
    To ensure that extension NICs can communicate with external networks, you need to configure policy-based routes for the NICs on the ECS after they are added.
    For details, see How Do I Configure Policy-Based Routes for an ECS with Multiple NICs?
Follow-up Procedure
Some OSs cannot identify newly attached network interfaces. In this case, you need to manually activate the network interfaces. The following uses Ubuntu as an example to show how to activate network interfaces. Operations may vary depending on the operating system. You can refer to the corresponding OS documentation for assistance.
  1. Locate the row containing the target ECS and click Remote Login in the Operation column.
    Log in to the ECS.
  2. Run the following command to view the network interface name:
    ifconfig -a
    In this example, the network interface name is eth2.
  3. Run the following command to switch to the target directory:
    cd /etc/network
  4. Run the following command to open the interfaces file:
    vi interfaces
  5. Add the following information to the interfaces file:
    auto eth2
    iface eth2 inet dhcp
  6. Run the following command to save and exit the interfaces file:
    :wq
  7. Run either the ifup ethX command or the /etc/init.d/networking restart command to make the newly added network interface take effect.
    X in the preceding command indicates the serial number of the network interface, for example, ifup eth2.
  8. Run the following command to check whether the network interface name obtained in step 2 is displayed in the command output:
    ifconfig
    For example, check whether eth2 is displayed in the command output.
    • If yes, the newly added network interface has been activated. No further action is required.
    • If no, the newly added network interface failed to be activated. Go to step 9.
  9. Log in to the management console. Locate the row containing the target ECS, click More in the Operation column, and select Restart.
  10. Run ifconfig again to check whether the network interface name obtained in step 2 is displayed in the command output:
    • If yes, no further action is required.
    • If no, contact customer service.
