Changing ECS Names
After an ECS is created, you can change its name as needed.
Multiple ECS names can be changed in a batch. After the change, the ECS names are the same.
Changing the Name of a Single ECS
- Click
in the upper left corner and select a region and project.
- Click
. Under Compute, click Elastic Cloud Server.
- Click the name of the target ECS.
- On the ECS details page, click
next to the ECS name and edit the name.
Allow duplicate name: allows ECS names to be duplicate. If Allow duplicate name is not selected and the new name you configure is the same as an existing ECS name, the system displays a message indicating that the name has been used and you need to change it to another name.
- Click
Batch Changing ECS Names
- Click
- Click
- Select the target ECSs.
- Above the ECS list, choose More > Change ECS Name.
- Enter a new name.
- Click OK.
If you batch change ECS names, the new ECS names are the same, for example, all are ecs-test.
