Logging In to a Linux ECS from a Mobile Terminal
If you want to manage Linux ECSs anytime, anywhere, you can log in to them from an iOS or Android terminal.
This section describes how to remotely log in to a Linux ECS from a mobile terminal using the username and password.
- For instructions about how to log in to a Linux ECS from an iOS terminal through Termius, see Logging In to a Linux ECS from an iOS Terminal.
- For instructions about how to log in to a Linux ECS from an Android terminal through JuiceSSH, see Logging In to a Linux ECS from an Android Terminal.
- The target ECS is running.
- You have obtained the username and password for logging in to the ECS. If the password is forgotten, reset the password by referring to Resetting the Password for Logging In to an ECS on the ECS Console.
- You have bound an EIP to the ECS. For details, see Binding an EIP.
- Access to port 22 is allowed in the inbound direction of the security group that the ECS belongs to. For details, see Configuring Security Group Rules.
- Start Termius and tap New Host.
Figure 1 New Host
- On the New Host page, set the following parameters:
- Alias: Enter the hostname. In this example, set this parameter to ecs01.
- Hostname: Enter the EIP bound to the target ECS.
- Use SSH: Enable it.
- Host: Enter the EIP bound to the target ECS.
- Port: Enter port number 22.
- Username: Enter root.
- Password: Enter the login password.
Figure 2 Setting parameters
- Tap Save in the upper right corner of the page to save the login settings. On the Hosts page, tap the name of the connection.
Figure 3 Login information
If the figure shown in Figure 4 is displayed, you have connected to the Linux ECS.
- Start JuiceSSH and tap Connections.
Figure 5 Starting JuiceSSH
- On the Connections page, tap
Figure 6 Connections
- On the New Connection page, configure basic and advanced settings and save the settings. The parameters are as follows:
- Nickname: Set the name of the login session. In this example, set this parameter to linux_test.
- Type: Retain the default value SSH.
- Address: Enter the EIP bound to the target Linux ECS.
- Perform the following operations to set Identity:
- Tap Identity and choose New from the drop-down list.
- On the New Identity page, set the following parameters and tap
- Nickname: Set an identity name as required to facilitate subsequent management. This parameter is optional. In this example, set it to linux_test.
- Password: Tap SET (OPTIONAL), enter the login password, and tap OK.
Figure 7 New Identity
Figure 8 Port
- On the Connections page, tap the created connection.
Figure 9 Connections
- Confirm the information that is displayed and tap ACCEPT.
Figure 10 Confirming the information
- (Optional) When you log in to the ECS for the first time, JuiceSSH displays a tutorial for you, including setting the font size and popping up the keyboard. Confirm the information and click OK - I'VE GOT IT.
Figure 11 Tutorial
You have logged in to the Linux ECS.
