Viewing ECS Details
After obtaining ECSs, you can view and manage them on the management console. This section describes how to view ECS configuration details, including its name, image, system disk, data disks, VPC, network interfaces, security group, EIP address, and bandwidth.
To view the private IP address of an ECS, view it on the Elastic Cloud Server page.
 - Click
 in the upper left corner and select a region and project. - Click
. Under Compute, click Elastic Cloud Server.
     The Elastic Cloud Server page is displayed. On this page, you can view the ECSs you have purchased as well as their details such as the specifications, images, and IP addresses.
 - In the search box above the ECS list, select a filter (such as ECS name, ID, or private IP address), enter the corresponding information, and press Enter.
 - Click the name of the target ECS.
The ECS details page is displayed.
 - View the ECS details.
You can click the tabs and perform operations. For details, see Changing a Security Group, Attaching a Network Interface, Adding Tags, and Binding an EIP.
