Updated on 2026-05-14 GMT+08:00
Detaching a System Disk
Disk Function
Server Status
System disk
Only offline detachment is supported.
You can only detach a system disk when the server status is Stopped.
  • If the file system on your system disk is damaged and the server cannot be started, you can detach the system disk and attach it to another server as a data disk. After the file system is fixed, you can re-attach the disk to the original server as the system disk.
  • If you no longer need a system disk or want to replace it with a new one, you can detach it.
Data disk
Both online detachment and offline detachment are supported.
You can detach a data disk when the server status is Stopped or Running.
  • If you want to use a data disk on another server in the same region and AZ, you can detach it and then attach it to that server.
  • If a data disk is no longer required, you can detach it and then delete it.
  • For an attached system disk, the disk function is displayed as System disk, and the disk status is displayed as In-use in the disk list. After the system disk is detached, the disk function changes to Bootable disk, and the status changes to Available.
  • Bootable disks are system disks that have been detached from servers. A bootable disk can be re-attached to a server to be used as a system disk or data disk depending on the disk function selected.
  • For an attached data disk, the disk function is displayed as Data disk, and the disk status is displayed as In-use in the disk list. After the data disk is detached, the disk function remains unchanged, and the status changes to Available. For a shared disk, the status changes to Available only after it is detached from all its servers.
  1. Log in to the console.
  2. Choose Compute > Elastic Cloud Server.
    The Elastic Cloud Server page is displayed.
  3. In the server list, locate the row that contains the server whose system disk is to be detached, click More in the Operation column, and choose Stop.
    When the server status changes to Stopped, the server has been stopped.
  4. Click the name of this server.
    The server details page is displayed.
  5. Click the Disks tab to view the system disk attached to the server.
  6. Locate the row that contains the system disk and click Detach.
    The Detach Disk dialog box is displayed.
  7. Click Yes to detach the disk.
    After the operation succeeds, the detached system disk is no longer displayed under the Disks tab.
  8. (Optional) Bootable disks are the system disks detached from servers. A bootable disk can be re-attached to a server and be used as a system disk or data disk depending on the device name selected.
