Managing Backups
DSS disk backups are created using CBR.
This section describes how to configure a backup policy for a disk. With backup policies configured, data on DSS disks can be periodically backed up to improve data security.
Backups can be created for disks only when the disks are in the Available or In-use state.
Creating a Disk Backup
Before backing up an EVS disk using CBR, you need to buy a disk backup vault, associate the disk with the vault, and then create a backup. Table 1 describes the procedure.
| Procedure | Description | Operation Instruction |
| Step 1: Purchase a Disk Backup Vault | Buy a disk backup vault to store disk backups. | |
| Step 2: Associate Disks with the Vault | Associate your disks with the vault to back up and replicate the disk data. | |
| Step 3: Create a Disk Backup | Create disk backups to protect data. |
