Updated on 2025-12-01 GMT+08:00
Extending Partitions and File Systems on Linux (fdisk)
In Linux, after the capacity expansion succeeded, the additional disk space needs to be allocated to an existing partition or a new partition.
This topic uses CentOS 7.0 64bit to describe how to allocate the additional disk space to a partition using fdisk.
The method for allocating the additional space varies depending on the server OS. This document is used for reference only. For the detailed operations and differences, see the corresponding OS documents.
Based on your service requirements and disk condition, you can choose either of the following ways to allocate the additional disk space:
  • Create a new partition (services will not be interrupted).
    Creating a new partition after expansion does not require the original partitions to be unmounted. Therefore, the impacts on services are minor than re-creating an existing partition. This method is recommended for system disks or disks carrying services that cannot be interrupted.
    If the MBR partition style is used, ensure that the disk capacity does not exceed 2 TB and the number of partitions does not reach the upper limit after the expansion.
  • Re-create an existing partition (services will be interrupted).
    If the MBR partition style is used and the number of partitions has reached the upper limit, you can only allocate the additional space to an existing partition. Re-creating an existing partition does not delete its data, but requires the partition to be unmounted. Therefore, services will be interrupted.
    If the MBR partition style is used and the disk capacity after expansion will exceed 2 TB, the space exceeding 2 TB cannot be used. To make use of that space, change the disk partition style from MBR to GPT. Data on the disk will be cleared during such a change. Therefore, back up the disk data before changing the partition style.
    Perform the expansion operations with caution. Misoperation may lead to data loss or exceptions. Therefore, you are advised to use CBR to back up the disk data before expansion. For details, see Managing Backups.
  • You have logged in to the server.
    • For how to log in to an ECS, see the Elastic Cloud Server User Guide.
    • For how to log in to a BMS, see the Bare Metal Server User Guide.
  • You have attached the disk to the server, and the additional space has not been allocated.
Checking File Systems on the To-be-expanded Disk
Before expanding the disk capacity, check whether the file systems on the disk can be properly mounted.
  1. (Optional) If there is an unmounted partition, run the following command to mount the partition on the specified directory:
    mount Disk partition Mount point
    Example command:
    mount /dev/xvdb1 /mnt/sdc
    If the system returns a mount error, check whether the file system is correctly created. For example, a user may create the file system for the /dev/xvdb disk instead of the /dev/xvdb1 partition. In this case, what mounted is actually the /dev/xvdb disk, but not the /dev/xvdb1 partition.
  2. Run the following command to view the disk mounting information:
    df -TH
    Information similar to the following is displayed:
    [root@ecs-b656 test]# df -TH
    Filesystem     Type      Size  Used Avail Use% Mounted on
    /dev/xvda2     xfs        11G  7.4G  3.2G  71% /
    devtmpfs       devtmpfs  4.1G     0  4.1G   0% /dev
    tmpfs          tmpfs     4.1G   82k  4.1G   1% /dev/shm
    tmpfs          tmpfs     4.1G  9.2M  4.1G   1% /run
    tmpfs          tmpfs     4.1G     0  4.1G   0% /sys/fs/cgroup
    /dev/xvda3     xfs       1.1G   39M  1.1G   4% /home
    /dev/xvda1     xfs       1.1G  131M  915M  13% /boot
    /dev/xvdb1     ext4       11G   38M  9.9G   1% /mnt/sdc
    In the command output, the file system of the /dev/xvdb1 partition is ext4, and the partition is mounted on /mnt/sdc.
  3. Run the following command to switch to the mounting directory to view the files on the disk:
    ll Mounting directory
    Example command:
    ll /mnt/sdc
    If the files on the disk can be viewed, the disk is normal and can be expanded.
Viewing the Partition Style
Before allocating the additional space, query the current disk partition style. If MBR is used, you can use either the fdisk or parted partitioning tool. If GPT is used, you must use the parted partitioning tool.
  1. Run the following command to view the current disk partition style:
    fdisk -l
    [root@ecs-1120 linux]# fdisk -l
    Disk /dev/xvda: 42.9 GB, 42949672960 bytes, 83886080 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disk label type: dos
    Disk identifier: 0x000c5712
       Device Boot      Start         End      Blocks   Id  System
    /dev/xvda1            2048    83886079    41942016   83  Linux
    WARNING: fdisk GPT support is currently new, and therefore in an experimental phase. Use at your own discretion.
    Disk /dev/xvdb: 161.1 GB, 161061273600 bytes, 314572800 sectors
    Disk label type: gpt
    #         Start          End    Size  Type            Name
     1           34    209715166    100G  Microsoft basic opt
     2    209715167    314572766     50G  Microsoft basic opt1
    Disk /dev/xvdc: 42.9 GB, 42949672960 bytes, 83886080 sectors
     1           34     16777215      8G  Microsoft basic opt
     2     16777216     83884031     32G  Microsoft basic opt
    In the command output, parameter Disk label type indicates the disk partition style. Value dos indicates the MBR partition style, and value gpt indicates the GPT partition style.
Creating a New Partition
The following example shows you how to make use of the additional space of a system disk by creating a new partition and mount the partition on /opt without interrupting services.
  1. Run the following command to view the disk partition information:
    fdisk -l
    Information similar to the following is displayed: (/dev/xvda is the system disk.)
    [root@ecs-bab9 test]# fdisk -l
    Disk /dev/xvda: 64.4 GB, 64424509440 bytes, 125829120 sectors
    Disk identifier: 0x000cc4ad
    /dev/xvda1   *        2048     2050047     1024000   83  Linux
    /dev/xvda2         2050048    22530047    10240000   83  Linux
    /dev/xvda3        22530048    24578047     1024000   83  Linux
    /dev/xvda4        24578048    83886079    29654016    5  Extended
    /dev/xvda5        24580096    26628095     1024000   82  Linux swap / Solaris
  2. Run the following command to enter fdisk:
    fdisk /dev/xvda
    [root@ecs-2220 ~]# fdisk /dev/xvda
    Welcome to fdisk (util-linux 2.23.2).
    Changes will remain in memory only, until you decide to write them.
    Be careful before using the write command.
    Command (m for help):
  3. Enter n and press Enter to create a new partition.
    Command (m for help): n
    All primary partitions are in use
    Adding logical partition 6
    First sector (26630144-83886079, default 26630144):
    If the MBR partition style is used, a maximum of 4 primary partitions, or 3 primary partitions and 1 extended partition can be created. The extended partition cannot be used directly and must be divided into logical partitions before use.
    In this example, the maximum number of primary partitions has been reached for the system disk, and the disk already has 5 partitions (3 primary partitions and 2 logical partitions). Therefore, the system automatically creates a sixth logical partition in the extended partition.
    To view the example operations in case that the maximum number of primary partitions is not reached for the system disk, see Extending Partitions and File Systems of a System Disk on Linux (fdisk).
  4. Enter the new partition's start sector, for example the default value, and press Enter.
    The start sector must be greater than the end sector of the existing partition.
    Using default value 26630144
    Last sector, +sectors or +size{K,M,G} (26630144-83886079, default 83886079):
  5. Enter the new partition's end sector and press Enter.
    The default end sector is used in this example.
    Using default value 83886079
    Partition 6 of type Linux and of size 27.3 GiB is set
  6. Enter p and press Enter to view the new partition.
    /dev/xvda6        26630144    83886079    28627968   83  Linux
  7. Enter w and press Enter to write the changes to the partition table.
    Command (m for help): w
    The partition table has been altered!
    Calling ioctl() to re-read partition table.
    WARNING: Re-reading the partition table failed with error 16: Device or resource busy.
    The kernel still uses the old table. The new table will be used at
    the next reboot or after you run partprobe(8) or kpartx(8)
    Syncing disks.
    The partition is created.
    In case that you want to discard the changes made before, you can exit fdisk by entering q.
  8. Run the following command to synchronize the new partition table to the OS:
    partprobe
  9. Run the following command to set the file system format for the new partition:
    (The ext4 file system is used in this example.)
    mkfs -t ext4 /dev/xvda6
    The procedure for setting the xfs file system is the same as that for the ext3 or ext4 file system. The command for creating the xfs file system is mkfs -t xfs /dev/xvda6.
    [root@ecs-bab9 test]# mkfs -t ext4 /dev/xvda6
    mke2fs 1.42.9 (28-Dec-2013)
    Filesystem label=
    OS type: Linux
    Block size=4096 (log=2)
    Fragment size=4096 (log=2)
    Stride=0 blocks, Stripe width=0 blocks
    1790544 inodes, 7156992 blocks
    357849 blocks (5.00%) reserved for the super user
    First data block=0
    Maximum filesystem blocks=2155872256
    219 block groups
    32768 blocks per group, 32768 fragments per group
    8176 inodes per group
    Superblock backups stored on blocks:
            32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
            4096000
    Allocating group tables: done
    Writing inode tables: done
    Creating journal (32768 blocks): done
    Writing superblocks and filesystem accounting information: done
    The formatting takes a while, and you need to observe the system running status. Once done is displayed in the command output, the formatting is complete.
  10. Run the following command to mount the new partition on a space-demanding directory, for example /opt:
    mount /dev/xvda6 /opt
    [root@ecs-bab9 test]# mount /dev/xvda6 /opt
    If the new partition is mounted on a directory that is not empty, the subdirectories and files in the directory will be hidden. Therefore, you are advised to mount the new partition on an empty directory or a new directory. If the new partition must be mounted on a directory that is not empty, move the subdirectories and files in this directory to another directory temporarily. After the partition is successfully mounted, move the subdirectories and files back.
  11. Run the following command to view the mount result:
    df -TH
    [root@ecs-bab9 test]# df -TH
    /dev/xvda6     ext4       29G   47M   28G   1% /opt
Re-creating an Existing Partition
The following example shows you how to use the additional space of a disk attached to a server by re-creating the /dev/xvdb1 partition and mounting the partition on /mnt/sdc. During this process, services will be interrupted.
During an expansion, the additional space is added to the end of the disk. When the disk has multiple partitions, only the partition at the end of this disk can be extended.
    fdisk -l
    [root@ecs-b656 test]# fdisk -l
    Disk /dev/xvdb: 21.5 GB, 21474836480 bytes, 41943040 sectors
    Disk identifier: 0xb00005bd
    /dev/xvdb1            2048    20971519    10484736   83  Linux
    In the command output, the total capacity of the /dev/xvdb disk is 21.5 GB, and the disk has only one partition, dev/xvdb1. The partition's start sector is 2048, and its end sector is 20971519.
    View the /dev/xvdb capacity and check whether the additional space is included.
  2. Run the following command to unmount the partition:
    umount /mnt/sdc
  3. Run the following command to enter fdisk and enter d to delete the /dev/xvdb1 partition:
    fdisk /dev/xvdb
    [root@ecs-b656 test]# fdisk /dev/xvdb
    Command (m for help): d
    Selected partition 1
    Partition 1 is deleted
    After deleting the partition, re-create the partition according to the following steps, and data on this disk will not be lost.
  4. Enter n and press Enter to create a new partition.
    Entering n creates a new partition.
    Partition type:
       p   primary (0 primary, 0 extended, 4 free)
       e   extended
    There are two types of disk partitions:
    • Choosing p creates a primary partition.
    • Choosing e creates an extended partition.
  5. Ensure that the entered partition type is the same as the partition had before. In this example, a primary partition is used. Therefore, enter p and press Enter to create a primary partition.
    Select (default p): p
    Partition number (1-4, default 1):
    In the command output, Partition number specifies the primary partition number.
  6. Ensure that the entered partition number is the same as the partition had before. In this example, partition number 1 is used. Therefore, enter 1 and press Enter.
    Partition number (1-4, default 1): 1
    First sector (2048-41943039, default 2048):
    In the command output, First sector specifies the start sector.
    Data will be lost if the following operations are performed:
    • Select a start sector other than the partition had before.
    • Select an end sector smaller than the partition had before.
  7. Ensure that the entered start sector is the same as the partition had before. In this example, start sector 2048 is recorded in 1. Therefore, enter 2048 and press Enter.
    Using default value 2048
    Last sector, +sectors or +size{K,M,G} (2048-41943039, default 41943039):
    In the command output, Last sector specifies the end sector.
  8. Ensure that the entered end sector is greater than or equal to the end sector recorded in 1. In this example, the recorded end sector is 20971519, and the default end sector is used. Therefore, enter 41943039 and press Enter.
    Using default value 41943039
    Partition 1 of type Linux and of size 20 GiB is set
    The partition is successfully created.
  9. Enter p and press Enter to view details about the new partition.
    Command (m for help): p
    /dev/xvdb1            2048    41943039    20970496   83  Linux
    Details about the /dev/xvdb1 partition are displayed.
  10. Enter w and press Enter to write the changes to the partition table.
    Syncing disks.
  11. Perform the following operations based on the file system of the disk:
    • For the ext3 or ext4 file system
      1. Run the following command to check the correctness of the file system on /dev/xvdb1:
        e2fsck -f /dev/xvdb1
        [root@ecs-b656 test]# e2fsck -f /dev/xvdb1
        e2fsck 1.42.9 (28-Dec-2013)
        Pass 1: Checking inodes, blocks, and sizes
        Pass 2: Checking directory structure
        Pass 3: Checking directory connectivity
        Pass 4: Checking reference counts
        Pass 5: Checking group summary information
        /dev/xvdb1: 11/655360 files (0.0% non-contiguous), 83137/2621184 blocks
      2. Run the following command to extend the size of the file system on /dev/xvdb1:
        resize2fs /dev/xvdb1
        [root@ecs-b656 test]# resize2fs /dev/xvdb1
        resize2fs 1.42.9 (28-Dec-2013)
        Resizing the filesystem on /dev/xvdb1 to 5242624 (4k) blocks.
        The filesystem on /dev/xvdb1 is now 5242624 blocks long.
      3. Run the following command to mount the new partition on /mnt/sdc:
    • For the xfs file system
      1. Run the following command to mount the new partition on /mnt/sdc:
        sudo xfs_growfs /dev/xvdb1
  12. Run the following command to view the mount result:
    df -TH
Configuring Auto Mount at System Startup
To automatically mount partitions at system startup, do not specify partition names, for example, /dev/xvdb1, in /etc/fstab because the sequence of cloud devices and their names may change during a server stop or start. You are advised to use the UUID in /etc/fstab to configure auto mount at startup.
UUID is the unique character string for disk partitions in a Linux system.
  1. Run the following command to query the partition UUID:
    blkid Disk partition
    For example, run the following command to query the UUID of the /dev/xvdb1 partition:
    blkid /dev/xvdb1
    [root@ecs-b656 test]# blkid /dev/xvdb1
    /dev/xvdb1: UUID="1851e23f-1c57-40ab-86bb-5fc5fc606ffa" TYPE="ext4"
    The UUID of the /dev/xvdb1 partition is displayed.
  2. Run the following command to open the fstab file using the vi editor:
    vi /etc/fstab
  3. Press i to enter the editing mode.
  4. Move the cursor to the end of the file and press Enter. Then, add the following information:
    UUID=1851e23f-1c57-40ab-86bb-5fc5fc606ffa /mnt/sdc      ext3 defaults     0   2
    UUID=1851e23f-1c57-40ab-86bb-5fc5fc606ffa /mnt/sdc      ext4 defaults     0   2
    The preceding content is used for reference only. Add the information that is used in the environment. The parameters are described as follows:
    • The first column indicates the partition UUID obtained in 1.
    • The second column indicates the directory on which the partition is mounted. You can query the mount point using the df -TH command.
    • The third column indicates the file system format of the partition. You can query the file system format using the df -TH command.
    • The fourth column indicates the partition mount option. Normally, this parameter is set to defaults.
    • The fifth column indicates the Linux dump backup option.
      • 0: not use Linux dump backup. Normally, dump backup is not used, and you can set this parameter to 0.
      • 1: use Linux dump backup.
    • The sixth column indicates the fsck option, that is, whether to use fsck to check the attached disk during startup.
      • 0: not use fsck.
      • If the mount point is the root partition (/), this parameter must be set to 1.
        When this parameter is set to 1 for the root partition, this parameter for other partitions must start with 2 so that the system checks the partitions in the ascending order of the values.
  5. Press Esc, enter :wq, and press Enter.
    The system saves the configurations and exits the vi editor.
