Help Center/ Domain Name Service/ User Guide/ Resolver/ Managing Endpoint Rules
Updated on 2026-07-08 GMT+08:00
To allow cloud servers to access an on-premises domain name, you need to create an outbound endpoint and configure endpoint rules to specify the on-premises domain name to be accessed and the IP addresses of the on-premises DNS servers. Huawei Cloud private DNS then forwards the DNS queries for the on-premises domain name to the on-premises DNS servers based on the endpoint rules.
An endpoint rule can have more than one VPC associated. After a VPC is associated with an endpoint rule, DNS queries for the on-premises domain name from the cloud servers in the VPC will be forwarded to the on-premises DNS servers.
  • The private domain name and VPC of an endpoint rule cannot conflict with an existing private domain name and its associated VPC.
    For example, if private domain name example.com associated with VPC A already exists, you cannot create an endpoint rule using the same domain name and VPC.
  • If a root domain is configured, all domain names except the private domain names will be forwarded to the DNS server you specified for resolution. Exercise caution when configuring the root domain.
  • If a private domain name is configured with a CNAME record pointing to a domain name of an endpoint rule, the target domain name must be configured on-premises.
  • An endpoint rule cannot be associated with a VPC that contains CloudDCN or CloudPond subnets.
Adding an Endpoint Rule
Before adding endpoint rule, you need to create an outbound endpoint. For details, see Creating an Outbound Endpoint.
  1. Go to the Resolvers page.
  2. Click in the upper left corner and select the desired region and project.
  3. Click the Endpoint Rules tab.
  4. Click Add Endpoint Rule.
  5. Configure the parameters based on Table 1.
    Figure 1 Adding a rule
    Table 1 Parameters for adding an endpoint rule
    Name
    Name of the endpoint rule added to an outbound endpoint.
    Domain Name
    Domain name used by on-premises servers.
    Only LA-Sao Paulo1 region supports root domain ".".
    CAUTION:
    Type
    By default, Resolver is selected.
    Outbound Endpoint
    Select the outbound endpoint that you want to add this endpoint rule to.
    Associate VPC
    Choose whether to associate VPCs with the endpoint rule.
    If this option is selected, you need to select one or more VPCs.
    Region
    Region that the VPCs belong to.
    This parameter is displayed after Associate VPC is selected.
    VPC
    Select the VPCs to be associated with the endpoint rule.
    IP Addresses
    IP address of a DNS server in the on-premises data center.
    You can add one or more IP addresses.
    • When you add multiple IP addresses, the servers are polled in sequence by default to ensure that requests are evenly distributed to each server.
    • Port 53 is the default port used by DNS servers. It cannot be customized.
    After an endpoint rule is added, the domain name, type, and outbound endpoint cannot be changed.
  6. Click OK.
Viewing an Endpoint Rule
  3. Click the Endpoint Rules tab to view the endpoint rule list.
    You can view the endpoint rules you created or other users shared with you.
  4. Click the name of the endpoint rule to view its details, such as basic configuration, VPCs, and IP addresses.
Modifying an Endpoint Rule
  4. Locate the endpoint rule and click Modify in the Operation column.
    You can change the rule name, associate other VPCs, disassociate VPCs, and add, delete, or change IP addresses.
    If only one IP address is configured for the endpoint rule, the IP address cannot be deleted.
Deleting an Endpoint Rule
  4. Locate the endpoint rule and choose More > Delete in the Operation column.
  5. Confirm the endpoint rule and click OK.
Disassociating a VPC from an Endpoint Rule
  4. Locate the endpoint rule and click in the VPCs column.
  5. In the Disassociate VPC dialog box, click OK.
