Updated on 2026-06-10 GMT+08:00
Disabling or Enabling Record Sets
You can disable a zone or its record sets on the DNS console. If you disable a zone or record set, it cannot be used for resolution. You can enable the zone or record set at any time if you need it again.
The domain name registry reviews the legitimacy of the website and forbids the access to the website during the domain name licensing. If you have added record sets on the DNS console, you need to disable them and then enable them after the licensing is complete.
This section describes how to disable or enable record sets.
The system-generated SOA and NS record sets cannot be disabled.
Disabling Record Sets
You can disable the record sets added to a domain name in the Normal state.
  1. Go to the Public Zones page.
  2. Disable record sets.
    • Disabling all record sets for a domain name: In the zone list, locate the target domain name and click Disable in the Operation column.
    • Disabling a record set: Click the target domain name to go to the record set list. Locate the target record set and click Disable in the Operation column.
    • Disabling multiple record sets: Click the target domain name to go to the record set list. Select the target record sets and click Disable above the record set list.
  3. Click OK.
    After a record set is disabled, it cannot be used for resolution, but you can view it in the record set list.
You can enable the record sets that have been disabled.
  2. Enable record sets.
    • Enabling all record sets for a domain name: In the zone list, locate the target domain name and click Enable in the Operation column.
    • Enabling a record set: Click the target domain name to go to the record set list. Locate the target record set and click Enable in the Operation column.
    • Enabling multiple record sets: Click the target domain name to go to the record set list. Select the target record sets and click Enable above the record set list.
  3. Click OK.
