Configuring a Wildcard DNS Record Set
A wildcard record set with its name set to an asterisk (*) can map all subdomains of the domain name to the same value. During domain name resolution, fuzzy match is used.
This section describes how to create a wildcard DNS record set.
- Wildcard DNS resolution does not support NS and SOA record sets.
- Exact match has a higher priority than fuzzy match for the same domain name.
- Go to the Public Zones page.
- Click the name of the zone to which you want to add a wildcard DNS record set.
- Click Add Record Set.
- Configure the parameters based on Table 1.
Table 1 Parameters for adding a wildcard DNS record set Parameter
Example
Type
Record set type
A – Map domains to IPv4 addresses
Name
Public or private domain name
Enter an asterisk (*) as the leftmost label of the domain name, for example, *.example.com.
NOTE:Only the leftmost asterisk is considered as a wildcard character. Other asterisks in the domain name are common text characters.
Line
A specific route or path that the DNS server uses to determine which IP address to return based on the user's location, ISP, or other attributes.
The default value is Default.
- Default: returns the default resolution result irrespective of where the visitors come from.
- ISP: returns the resolution result based on end users' carrier networks. For details, see Configuring ISP Lines.
- Region: returns the resolution result based on end users' geographical locations. For details, see Configuring Region Lines.
- Custom Lines: returns the resolution result based on specified IP address ranges. For details, see Configuring Custom Lines.
Default
TTL (s)
How long a local DNS server caches a DNS record. It is measured in seconds.
Default value: 300
Value range: 1 to 2147483647
If your service address changes frequently, set TTL to a smaller value. Otherwise, set TTL to a larger value.
300
Value
Returned result of domain name resolution.
For details about how to configure the value for each type of record set, see Table 1.
The following uses an A record set as an example:
192.168.xx.2
192.168.xx.3
Alias Target
Cloud resource to be associated with the alias record set, which includes the cloud resource name and alias target.
Enterprise Web Portal and example.com
Weight
Weight for the record set.
Default value: 1
The value ranges from 0 to 1000.
If a resolution line in a zone contains multiple record sets of the same type, you can set different weights to each record set. For details, see Configuring Weighted Routing.
Tag
Identifier of the record set. Each tag contains a key and a value.
You can add up to 20 tags for a record set.
The tag key:
- Cannot be left blank.
- Must be unique for each resource.
- Can contain a maximum of 128 characters.
- Cannot start or end with a space, or cannot start with _sys_. Only letters, digits, spaces, and the following special characters are allowed: _.:=+-@
The tag value:
- Can be left blank.
- Can contain a maximum of 255 characters.
- Can contain letters, digits, spaces, and special characters _ . : / = + - @.
NOTE:If your organization has configured tag policies for the DNS service, you need to add tags to your record sets based on the tag policies. If you add a tag that does not comply with the tag policies, record sets may fail to be created. Contact the administrator to learn more about tag policies.
example_key1
example_value1
Supplementary information about the record set.
The description can contain a maximum of 255 characters.
This is a wildcard DNS record set.
- Click OK.
- Switch back to the Record Sets tab.
The wildcard DNS record set in the Normal state.
For details, see How Do I Check Whether a Record Set Has Taken Effect?
